11-05-2013 | #51 |
Re: wheel refinishing?
If these wheels are going to be "with you" for a while doing the "four" creates a "known" - doing two regardless of process certainly leaves the possibility of "disappointment". Doing the "four" also creates the known for a future need if there should become a need for a single or touch up of sorts.
Borrow a set of something in the vicinity to store the car on, do the four in what ever process you determine to be economical and can produce your desired results. There's no second thought of if you made the right choice or not. Are your intentions to use the hardware over? |
11-05-2013 | #52 |
They are Aluminum, right???
11-05-2013 | #53 | |
Yes aluminum wheels
11-05-2013 | #54 |
I was more curious about your plans, I would doubt the titanium hardware because of the initial expense when constructed. Titanium is usually an option that costs sometimes considerably more. It's then debated whether you replace nuts or bolts or both. I don't know the original build specs but the argument bolts or nuts get more involved. Are the nuts "ny-loc" or just "prevailing torque" or neither and just maybe lock-tited? Titanium unless an alloy with a high iron content I don't believe is considered highly magnetic. Yours?
11-05-2013 | #55 |
So I don't know what the material is, i can take a magnet to it and see.. Last time I had them apart I used Blue Lock Tite and torqued to 18-20 ft lbs
I was planning on doing the same, if I can find out what material the bolts are I have one wheel with different style bolts, it would be nice to have all 4 the same.. Would if someone at speedline would know
11-05-2013 | #56 | |
You could "chuck-up" the bolts I'd think in a rotary tool and polish with steel wool. 40 times per = awhile! Last edited by WVZR-1; 11-05-2013 at 10:41 PM. |
11-05-2013 | #57 |
Yeah I am going by memory, it might have been 25
I do agree I should be able to find one fo the 2 styles to match.. my luck is I will find the match where I will need 120 .. LOL
11-11-2013 | #58 |
Okay,
Went to the wheel refinisher today. He has a color/metallic that will be close to what I have. I bring him 4 centers.. $300 Out the door ($75 each) now I need to break them down and drop them off.. Sounded like less then a week to do.. (essentially a couple days)
11-11-2013 | #59 |
That's more like it "$300"
11-11-2013 | #60 |
right, before I was getting a verbal without seeing it quote..
Now I have it written down from them on a card.. It is convenient to get them there and pick them up.. Need to disassemble them now
