09-09-2013 | #51 |
Re: engine wear
Ron and I were talking with steve's corette parts out of staten island at carlise and I think they had some radios for the early cars. I tried their site stevescorvetteparts.net and it seems to be down, but it does have a phone number 374-217-0362
09-09-2013 | #52 |
Re: engine wear
I use AMSOIL 10W 40 but others have their own Preference
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-09-2013 at 05:25 PM. |
09-10-2013 | #53 |
Re: engine wear
I think that removing the oil pan, baffle, pick-up tube, cleaning everything up and getting all the junk removed , and ops check the low oil sensor would be great preventative maintenance. Love to see pictures on this. How do you support the engine and remove the pan if you raise the engine with a 2x4 under the pan? How do you support it?
Thanks. |
09-10-2013 | #54 |
Re: engine wear
I just lifted the engine to get all bolts out of the front of the pan. Then lowered it back down and removed the heat shields from around the converters, removed the last four studs and had to wiggle the pan to get it out. But it came out relatively easy. I think I spent more time searching around for tools then actually getting the pan out.
09-15-2013 | #55 |
Re: engine wear
Well pan gasket number one was a failure. It still leaks. Going to recheck I torqued everything correctly then go from there. At least everything is clean and it should only take about an hour to get it all apart.
09-15-2013 | #56 | |
Re: engine wear
When you have everything in place and bolts in place with some snugged up, you can see the gasket between pan and block....visibly make sure the gasket is at the edge of the pan as you torque the bolts ALL AROUND AND EVEN. If the gasket starts moving on you....suspect oil or something on gasket. |
09-15-2013 | #57 |
Re: engine wear
It's leaking from the front so I'm thinking either the gasket moved a bit or I over/under torqued those little bolts. I torqued everything in sequence according to the manual.
09-16-2013 | #58 | |
Re: engine wear
If you used anything on the gasket it is best to let it get real tacky (almost dry) so the gasket does not slip around. Do NOT forget the "O" ring on the Oil Pickup (Oil Pump Suction Pipe Seal). Keep an eye on the gasket as you tighten bolts to make sure it stays even with the outer edge of the oil pan/block.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-16-2013 at 03:16 AM. |
09-16-2013 | #59 | |
Re: engine wear
The reason I ask is sometimes you can end up chasing your tail on such things. There a are some well known sources of leakage at the front of the engine on the passenger side. They end up dribbling along side the engine almost invisibly until the reach the pan. Just food for thought.
09-16-2013 | #60 |
Re: engine wear
Read this from Haibeck on finding and fixing oil leaks on LT5.
http://www.zr1specialist.com/HAT%20W...0the%20LT5.pdf |
