08-23-2013 | #51 |
Re: About to start header install just wanted some input and had a few questions...
So there's no valve and no possibility of codes right? I'm sure ill see once I drop the manifold and can see the full length of the hose/tube. Ill pound a screw in there as well maybe pop by the steel shoppe nearby and have them weld it at the head to prevent any leaks as the o2 is downstream.
Kicking myself for not having SW eliminate it grr. Thank god I remembered to delete the air I would have cut them off before Installation. Mike what brackets are you referring to? |
08-23-2013 | #52 |
Great writeup.
I will be starting my installation very soon and will be able to use some of your writeup as reference. What I found interesting is the difference in headers as I thought the SW ZR-1 header was all the same but there are differences in tube length and collector design. I ordered mine with the performance connect as I will be doing an FBI style Exhaust and getting rid of my Borla. Take a look at the differences between my header and 5ABI VT'S header with Factory Connect. Not trying to hijack, just posting an observation. 4-cam
[I]4-cam[/I] [I]1991 ZR-1 Blk/Gry #31[/I] [I]SW Headers/Xpipe- Dynomax Muffs[/I] [I]Ported top end[/I] [I]Secondaries Removed[/I] Tune by Dominic Last edited by 4-cam; 08-23-2013 at 02:26 AM. |
08-23-2013 | #53 |
No hijack at all I mentioned it earlier in my thread.
I almost wish I went with the performance connect as well but for ease of install at home and for fitment with a corsa I didn't have much of a choice. The merge is longer And a smoother transition for the primaries.. It makes the factory connect look like a mid length or shortly header :/ Saving grace for me was they're still WAY better than the factory manifolds. |
08-23-2013 | #54 |
What did you guys do with the port on the plenum side for the egr?
08-23-2013 | #55 |
I would just like to offer my thanks for your efforts to let us all know what we will be looking at for this job. Specially those of us that will be doing this on the floor! LOL
This took effort on your part and I say a big "Thanks!" that you took the time to help the rest of us. After reading your account and Cliff's I think I have been well briefed in what "to be on the look out for". Tom
08-23-2013 | #56 | |
Eliminating EGR on 93'- 95' LT5
The L98 and LT5 EGR ports on Plenum are NOT the same (The center to center on L98 EGR Cover Bolts is 1.75 inches and on LT5 center to center of EGR flange bolts is about 1.5 inches). I recommend you cut out a nice EGR cover out of 1/4 aluminum stock and drill as shown in the third photo below (the second photo is one I bought with SS Allen Head bolts). LT5 (93'-95') EGR Plenum Port.................................................. .....L98 EGR Intake Manifold Port EGR Cover Plate made from 1/4 inch ALuminum Plate and Drilled to fit. And........... if anyone wants to know about installing SW Headers on an L98 as well as eliminating the L98 Air Pump and EGR... I have done that also This L98 powers a ZF S6-40 six speed Transmission. Cliff
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-23-2013 at 12:14 PM. |
08-23-2013 | #57 |
The last photo you posted...if I'm not mistaken, they are still installed- the are the 15" long diagonal braces that sort of form a "K" shape. I guess you could maybe do the job without removing them, but it makes getting the O2 sensor wiring off a little easier on the passenger side. They do not support the motor mount even though it looks like they do.
08-23-2013 | #58 | |
08-24-2013 | #59 |
Just the header or header & cat?
[I]4-cam[/I] [I]1991 ZR-1 Blk/Gry #31[/I] [I]SW Headers/Xpipe- Dynomax Muffs[/I] [I]Ported top end[/I] [I]Secondaries Removed[/I] Tune by Dominic |
08-24-2013 | #60 |
