Closed Thread
Old 11-25-2012   #51
Hib Halverson
Default Re: Gross Horsepower LT-5
(snip)
Hib...You said Barney measured 413 at the wheels. You used 18% drive line loss to predict you have about 504 net hp at the crank.
That's correct. Actually, that session was three passes on the Dynojet at K&N Engineering near the end of the period when the car was a "project vehicle" for "Vette Magazine." It was two runs at 410 and one at 413. There were also a few in the high 400s, but that was with a different calibration.
My 90 Z measured 432 hp at the wheels, using SAE/Marc's 15% drive line loss, my net crank calcs to be 508 hp. Now, going on net crank hp and nothing else, I imagine it would be a near toss-up in the quarter mile, all things being equal. Care to race and compare??
P.
Well, uh...(choke)...
I don't know how this thread ended up being a wee-wee length contest. I thought we were talking about how GM has rated engines, the differences between the old "gross" power rating system and the current "SAE net" power rating system and the ins-and-outs of comparing power output using dynos.
But...I will conceded, Paul, that your weenie is bigger.
Likely you'd wipe my sorry butt all over the track seeing as you have headers, shorter gears, more power to the ground and significant drag racing talent revered by most here on the ZR1 Net Forum.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Last edited by Hib Halverson; 11-25-2012 at 10:23 AM. Reason: edited to be shorter
Hib Halverson is offline
Old 11-25-2012   #52
scottfab
scottfab's Avatar
.....snip.....
Where the rubber meets the road is where real performance is demonstrated...I think is the main point ... at least it is for me.
...snip..
P.
Well put.
Scott
scottfab is offline
Old 11-25-2012   #53
A1990
A1990's Avatar
Pretty much why you judge power on basis of trap speed not ET. Trap speeds can vary based on track setup.
I think this pretty much sums up this discussion, there is no one right answer as Dom ends up arguing with himself.
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline
Old 11-25-2012   #54
Fully Vetted
Fully Vetted's Avatar
Yeah, I was trying to figure that out. Thought it was just me...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Fully Vetted is offline
Old 11-26-2012   #55
Ins-and-outs of comparing power output via dynos...WAS exactly my point!
Engine output and how it is measured has been a delema for real engineers for some time, hence references to the evolvement of various SAE standards for measurement, and their revisions over time. And, I was agreeing (somewhat, perhaps) with you with regard to the ambeguity ("grain of salt", you said) that results between direct vs. indirect measurements.
You misunderstood my piont; no dick-measuring at all. Take "yours and mine" out of the discussion and say A = 504 net chp via 18% correction between the tire and the flywheel, and B = 508 net chp via 15%. That amounts to a 1% difference in net chp - well within the margin of error to the point of being essentially the same.
However, measured at the tire, B = 4% more than A. We can agrue the differnces between dynos too, but all things being equal, which horse are you going to bet on in a race? Again...reinforcing your agruement regarding (essentially) the pitfalls of extrapolating measurements via indirect methods, and my point that measurements at the tire are much more indicative of motor output, but terminal velocity resulting from WOT accelleration testing is probably superior to anything else we have to determine real performance, i.e., where rubber meets the road...maybe.
Interesting discovery... In boning up on SAE standards re this topic, I ran across "taxible horsepower". Essentially a British standard where a horsepower tax was levied on manufactures where the number of cylinders and bore diameter were the key ingredients in the calculation. As result, Jaguar (and others) motors in the 50s were built with fewer cylinders and strokes significantly longer than bore diameter. Eventially, the standard was relaxed in order to compete effectively with other world manufactures that were trending toward over-square bore/stroke via bore diameter. Another example of govenment and unintended consequences. Makes ya wonder what sports cars would be like w/o any restrictions, huh? Supercharged V12s or V16s maybe?
Anyway...I agree w/ others that this topic has probably been beat to death...long ago.
P.
P.
Paul Workman is offline
Old 11-26-2012   #56
Blue Flame Restorations
Beaten like a drumb.
You can lead a horse to water..............but if the horse thinks he knows everything there is to know about water.....................
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Blue Flame Restorations is offline
Old 11-26-2012   #57
scottfab
scottfab's Avatar
... snip...
...snip...
Definitely time to close this one.
But that Hib quote would be a nice addition to Paul's signature
Scott
scottfab is offline
Old 11-26-2012   #58
QB93Z
QB93Z's Avatar
This discussion has run its course. The tread is now closed.
QB93Z is offline
Closed Thread
