#51 |
![]() Join Date: Sep 2011
Does someone make a smooth boot rather than the accordian thingy
#52 | |
![]() Join Date: Feb 2009
I thought about putting the buffer to it....maybe too "Blingy" huh? Rich
#53 |
![]() Join Date: May 2011
#54 |
![]() ![]() Join Date: Feb 2010
I may PC mine the same color as my LT5.
#55 |
#56 | |
![]() Join Date: Jul 2004
Well how do you mean? I was talking about its time for me to make my own run since this will be the only run he is doing. oh hell im not going to be able to do it anyway
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. Last edited by phrogs; 03-30-2012 at 08:51 PM. |
#57 | |
I may do them for future needs.
#58 | |
![]() Join Date: Nov 2007
I built mine from some 16 ga. aluminum sheeting - folded into an oval with the seams held by pop-rivets. ![]() Prior to drilling and putting in the rivets, I slipped the sleeve into the accordion and then expanded the sleeve for a snug fit, and then drew a line on the inside of the sleeve, along the under lapped edge. The seam is a bit crude, but functional AND not visible. (If I had a TIG welder, it could have been almost seamless. That would be the bee's knees, but I digress...) In addition to the support of the accordion tube, by extending the sleeve under the lip of the plastic filter air box, the lip becomes sandwiched between the sleeve and the hose clamp/accordion tubing. This serves in eliminating the annoying habit of the accordion slipping off of the filter box. (AND, for good measure, a sheet metal screw or two can be installed after drilling trough the bottom side of the hose clamp/accordion, filter box lip, and into the sleeve underneath it all to secure all those pesky joint members - the hose clamp included! ![]() "Nourishment for contemplation" ![]() P. Last edited by Paul Workman; 03-31-2012 at 09:20 AM. Reason: spelling |
