Old 02-04-2012   #51
Default Re: Finally Heads are Done
Wow that is really impressive - no rattle at all -- you were not kidding about solving the issue!
Amazing to me that a tune, injectors and a tranny oil change can make the difference.
Like they say >> Hearing is Believing. And in this case seeing as well.
So no idle rattle now -- How about the rut-rut-rut when lugging 1st or 2nd gear under low rpm? Was this improved as well?
Old 02-04-2012   #52
cvette98pacecar
Originally Posted by WB9MCW View Post
Fidanza's Rule -- Just have to get use to the dreaded "gear rattle".
Having a nice ceramic clutch from Carolina Clutch helps a lot as well IMO.
I remember the first time I heard the rattle, I thought I spun a bearing.
Old 02-04-2012   #53
Rattle will appear in idle after long hot run which indicates trans fluid thinning.
No rattle in any gear at any point.
