#51 |
![]() Join Date: Jan 2009
Morning update:
No sign of grease pencil under hood that I could find. More electrical testing: 1. Passenger side blinkers work. 2. Drivers side lights up but does not blink 3. Passneger side door hatch release works 4. Drivers side door hatch release doesnt work 5. Center console hatch release works. 6. New installed horn button works. 7. Only high pitch horn works. 8. High beams work 9. Green arrows do not light on dash when either blinker is on 10. High beam indicator on dash does not light up. |
#52 |
I emailed Sean Finegan from GM this morning to look into the tach issue. Sean was the GM rep at the Auction and he helped me document #074 last year. He replied back and said he would see what he can find.
#53 |
#54 |
Checked the Ignitian today to see if the VATS resistor is working. It was:
Key is a 4 and the vats check reads: Since that works now I may try the 4 minute start option just to see if maybe the key is wrong. |
#55 |
Pulled the drivers door panel to fix the hatch release and repair the upper trim. Found the original color:
Any idea what this resistor is for? Pulled this plug off of the break pedal: |
#56 |
Update:
Put the Tech 1 on it this afternoon and guess what..... Code 46!!! Vats problem Here is my question. Where is the VATs code stored? in the ECM? If so this has a refurbished ECM. So... |
#57 |
![]() Join Date: Jul 2007
in a regular RPO there is a VATS Module on the Passenger side that controls it. there is a flag in the ECM on the 89 L98 to ignore the VATS.
My guess is the vats module is the same on your behind the breadbox
#58 | |
![]() Join Date: May 2005
There is a tool that can bypass/check the vats its called a vats checker, I used one on mine when we could not get it started. Tyler |
#59 | |
Tyler |
#60 |
Thanks for the info. I did not want to start with the wiring yet, but this afternoon I reattached the courtesy light plug connectors to the white and orange wires. Next thing you know. I'm pulling codes.
