#51 | |
![]() Join Date: Dec 2003
WOW,that's the strongest stocker i've seen yet. Should run 117-+1 I should add from what i have seen from 370rwhp on DynoJet Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 01-17-2010 at 03:26 PM. |
#52 | |
![]() Join Date: Aug 2006
#53 | |
![]() ![]() ![]() I can figure out MPH, that's not a problem. Just not a the top of my list. Not a big deal to me. I'll maybe take it to the track this year, we'll see. Did my 90 just for fun, had a couple oil leaks to fix, Cooler lines & Breaher Box plus I wanted to add valve seal's to the Exh. so while I was in there... ![]() Last edited by flyin ryan; 01-17-2010 at 06:12 PM. |
#54 | |
![]() Join Date: Nov 2007
In one corner we have a group that has demonstrated some pretty substantial numbers, both on dynos and the track using ports at or above the vaunted "36mm", and in the other corner a professional builder that says smaller is better. What we need is a volunteer mule car, someone that would agree to bolting on plenums and IHs from each approach and see what what happens. We could be talking dyno comparisons (the same dyno/same day) and track times too. I have a plenum and IHs out of the car at the moment - with "good ol boy" ports. someone wanna put together some not so big ports e.g., well under 36mm and see what is what???? Any takers? I would be very interested to see a direct same-day same-car comparision. What U think? (and again...apologies to the OP for railroading his post.) P. Last edited by Paul Workman; 01-17-2010 at 10:10 PM. |
#55 |
Todd would be the obvious choice if he's willing, don't need to do the work, it's already done
#56 |
there is a 2 day test and tune @ famoso the 3 rd weekend in feb . on my 90 are the siamesed injector housings and dividerless plenum . my 92 has the callaway ported inj housings and plenum which are on the smaller side .stk gaskets plenum and injector housings work on the callaway, i could try the 2 different setups on the callaway and see , but to be fair i would think the callaway setup would have to be sent to ryan for him to look over and adjust . pete know how the callaway porting looks ,maybe he can chime in . i would be more than happy to be the test mule. i could get my buddy jeremy to video the whole deal .
#57 |
For the record, it's not 'A engine builder...(Me)', obviously Todd's guy has parallel thinking as myself, especially considering his cubes. Funny, the world I live in 'Big' is in the minority...
#58 | |
#59 |
![]() Join Date: Mar 2007
#60 |
More thoughts.
Ryan i'm not saying bigger is better or more power. I have tested big siemesed plenum with big siemesed IH's on my 350 and dyno tested with no gains, yes there is a point where too big you don't gain anything. I will also add cam timing is worth power Now on big inch motors it might be a different story. Here is what i have tested. Tested the Hogan's intake on the 421ci it gained 10-12rwhp over the stock ported intake. Made a believer out of me on LPE's droped & siemised plenum & IH's he had sad it was worth 15 chp. Of course peak power was a couple hundred RPM higher this might be the effect of the shorter & straight runners also the Hogan's intake box/plenum is bigger then stock plenum. Man did we ever screw Todd,sorry Todd ![]() Maybe start a new thread. If we can get a couple of sponsers for gaskets,car,dyno time/expense we can do the testing that Paul mentioned. I'm also interested to see what the magic porting # would be. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 01-18-2010 at 04:51 AM. |
