10-29-2015 | #51 |
Re: Stalling issues - Code 31 (Camshaft Position Sensor)
Thanks vilant, I will receive my cam sensor next week, if my stalling issue is still fixed by then and if after the new cam sensor is installed I still got the Code 31, I'll have to think ECM.
But I guess good luck finding a ECM somewhere... |
10-29-2015 | #52 |
Alright stalling issue is definitely fixed now, another 10 miles without the problem.
BUT. The SES light comes on way more often. |
10-29-2015 | #53 |
I've red that on another forum...
Strange enough, alternator failed last week (changed by a new one). Do you think I can simply clear the code...? If so, how do I do that? |
10-29-2015 | #54 |
When my cam sensor went out it acted just like your car. I think once you change the sensor you will be OK. In general ECM failures are rare.
10-29-2015 | #55 |
10-29-2015 | #56 | |
ALDL Fault Code Reader/Eraser on CF. |
10-29-2015 | #57 | |
10-30-2015 | #58 |
I erased the code 31 by unplugging the battery 10 seconds - never came back after a 200 miles ride today.
Stalling issue happened twice, map sensor hose was still too long and bent a bit - cut it again. Hope it fixed the issue for good. |
10-31-2015 | #59 | |
Here is what it's supposed to look like.
10-31-2015 | #60 |
The answer to my stalling issue is that hose for sure Jerry so I will look into that.
Thanks a lot! |
