Old 11-12-2020   #561
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
Making progress with the positive battery cable replacement....
Everything is apart...was debating on removing the starter and doing a cleanup...but may just leave as it is and clean what I can....
Pic #1....yes we know how crowded it is under there....lol
Pic #2....that tape gun tape doesn't stick... [emoji848]....now what plug goes where....[emoji16][emoji16]
Pic #3....connections everywhere... great opportunity to get everything cleaned...
Pic #4....glad I removed the coils from the cover plate...needs a cleaning....
Pic #5...and there it is....the positive battery cable connection....was thinking about starter removal...but now....thinking not....[emoji16]20201111_222659.jpg20201112_125729.jpg20201112_133014.jpg20201112_133437.jpg20201112_134925.jpg
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 11-12-2020   #562
Ccmano
Ccmano's Avatar
Since you have gone to that trouble, I would at least pull the starter and check/clean the solenoid contacts.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 11-12-2020   #563
Roadster
Roadster's Avatar
H
The starter was replaced about 4 or 5 years ago when we did the first plenum pull on the 94...and only has a thousand miles on it if that since that pull....was thinking of taking it out just to clean up there more thoroughly.... but then thinking not...lol.... I'll see what tomorrow brings....[emoji16][emoji16]
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 11-13-2020   #564
32valvZ
32valvZ's Avatar
Dude.... pull the starter... clean it up and clean that valley up too. Youve gone too far not to.
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 11-14-2020   #565
Roadster
Roadster's Avatar
Well I did end up removing the starter and did a cleanup in the valley...the drain hole was clear....as that was taken care of with the 1st plenum pull years ago...some pics.... btw...the FSM....mentions to torque the starter bolts to 38 lb ft.... is any type of sealer or anti seize recommended???
Pic #1...some cleaning needed for sure...
Pic #2...there is some crud there....lol...
Pic #3...used a 14" plastic tie for the drain hole....clear all the way through...
Pic #4...wiped out and looking like it should....
Pic #5...as clean as can be...an improvement from before....
Pic #6...starter back in...bolts need to be torqued down....thinking about a dab of anti-seize for future removal....
Another job added to the finished column....
20201114_135725.jpg20201114_135809.jpg20201114_140552.jpg20201114_160311.jpg20201114_155631.jpg20201114_162755.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 11-14-2020   #566
32valvZ
32valvZ's Avatar
I know of no sealant needed for the starter mounting... Looking good now!!
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 11-14-2020   #567
Roadster
Roadster's Avatar
Thanks....it does look better.... might just torque them down with the anti-seize....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 11-15-2020   #568
Roadster
Roadster's Avatar
Replacement positive battery cable installed....had to use original ground wire....no biggie...just had to retape to replacement....[emoji16]20201115_130621.jpg20201115_130631.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 11-16-2020   #569
Roadster
Roadster's Avatar
More progress today....cleaning up more under the plenum....
Pic #1...from this....
Pic #2...to this....
Pic #3...and this....
Pic #4...to this...
Pic #5...going to remove the AC compressor and the alternator for a full cleaning....and most likely the belt tensioner while I'm at it....lol
before you know it I'll have the entire car disassembled......[emoji16][emoji848][emoji16]20201116_150413.jpg20201116_155508.jpg20201116_155801.jpg20201116_162327.jpg20201116_162500.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 11-17-2020   #570
Roadster
Roadster's Avatar
Coil tray cleaned and ready for install....back in the engine with colis and wires attached....20201117_142635.jpg20201117_151605.jpg20201117_164451.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
