06-12-2012 | #551 |
Re: LT5 Assembly Project
Somebody show Tony a vid of Bob G's 427. Maybe where he runs 135mph 1/4mile.
06-12-2012 | #552 | |
Interesting to know if a stock crank have a rod journal damage can be offset regrind to 2" and go to 2" journal chevy rod. The BIG Bore from AES 4.165 only for BIG POCKETS $$$$$$$$$$ "It can be pushed out to 3.80 on smaller Honda 1.890 journal " This engine is international !!!, England (Lotus) design, Usa (GM) paid $$, France (Carcassone) presentation, Japan (Honda) Internal powered, and porting and tuned by enthusiasts all over the world. And only 6.939 where made I will post a revised LT5 stroke PDF Toni
Toni Pujol 1994 Black on Black ZR1 #080 my brother is Ramon (93ZR1Barcelona) 1993 Black on Light Grey ZR1 #317 Want to belong to 500+ HP ZR1 club 350 Engine ready to assemble. Full porting done (Heads, IH, Plenum,TB63, Air Horn) Pete reground cams. Fidanza Borla+SW Heders+SW Xpipe C5 Z06 front Brakes DeWitts Radiator Home made shrowd + 2 speed Motorcraft single fan. Mopar 4.10 pinion & ring Last edited by Toni94ZR1; 06-12-2012 at 08:07 PM. |
06-12-2012 | #553 |
06-12-2012 | #554 |
[QUOTE=Toni94ZR1;143283]OOOOOOh men this is the secret !!!!! an offset 2” rod journal .
King bearing makes the 1 piece conversion bearings 2.100 to 2.000 No Spacer needed!! |
06-12-2012 | #555 |
What's wrong with 401ci's for $10k completly done short block.
Closed deck,new pistons,new rods.crank offset to 3.75,bore 4.125 and can use stock head gaskets. If you go with bigger bore where do you get head gaskets? Pete
06-13-2012 | #556 |
you go with MLS gaskets and tell them the bore size you need.
06-13-2012 | #557 |
Ok,i would think they are a bit pricey,but as long as we have something. Heck then we can make a 454ci Pete
06-13-2012 | #558 |
3.750 x 4.390 454
I don't think the block will go that far out Daryll went with the MLS gaskets on the 380. I think they were $350 but reusable. |
06-13-2012 | #559 | |
4.125 X 4.175 and lets just call it a 454 close enough
06-17-2012 | #560 |
Car has been running great. 2 issues.....leak at the front of the motor, not the pan. Thought it was the oil filter housing, but starting to wonder if its the front crank seal. I am seeing oil dripping from the trans inspection cover also.....
Thought it was solved yesterday as I drove it with no leaks. Today I ran the car up to 5K....and leaks...starting to think its the front/rear seals. Any thoughts? Leaks are wet spots....no large puddles, etc. Happened too many times to be residual..... Everything is new and rear seal torqued to spec
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 06-17-2012 at 12:45 AM. |
