10-23-2020 | #551 |
Re: TB removal and then some!!!
That washer looks like it or suitable replacement
would be available at any hardware store for a few cents? What's so special about it? |
10-23-2020 | #552 |
Tom,
I have a new (NOS) 12106586 which I have listed as correct for 93-95 Corvette ZR-1 Maybe my listing is wrong, but the cable looks correct. Let me know. Thanks and Good Work!!! Marty |
10-24-2020 | #553 | ||
10-27-2020 | #554 |
FYI...lesson learned.....the washer shown above part#11501869 is not for the battery cable end that attaches to the battery.....rather than it is for the "ring" ends that attach to the other connections.....which are much smaller....
10-29-2020 | #555 |
In the process of changing the bias spring in the MC....but a no go for now....might just unbolt and try it on the work bench....
Also removed the rocker panel on the LS...thinking about getting them repainted....also a cleanup in the area is needed...and the fasteners were soaked....cleaned and dried and getting ready for paint...20201028_212719.jpg20201028_212858.jpg20201028_213452.jpg20201029_173241.jpg20201029_173251.jpg20201029_173308.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 10-30-2020 at 01:40 AM. |
10-30-2020 | #556 |
Started to unwrap the rear wiring harness to replace the electrical tape...big mistake...that ended in a hurry...lol
Just re-taped over the old tape after cleaning....another job completed [emoji16]20201030_161735.jpg20201030_173720.jpg20201030_173629.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
10-30-2020 | #557 | |
10-30-2020 | #558 |
I have no idea....seems to be a strand type electrical type tape that I am not familiar with....as mentioned I didn't remove anymore...just covered it all...[emoji16][emoji16]20201030_161735.jpg
10-31-2020 | #559 |
Took the conduit off the rest of the rear wiring harness to cleanup the wires....26 years of some buildup in there...
Wires wiped down.....conduit replaced and taped.... Last pic is comparison of the new on the left and the original on the right....new is more flexible.... original seems stronger....but that can be from different grades of the material....or just feeling like that with age....another job completed.... still more to do....[emoji16]20201031_164712.jpg20201031_165606.jpg20201031_170427.jpg20201031_172308.jpg20201031_172441.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
11-01-2020 | #560 |
Making more progress today...
Pic #1...took fuse boxes apart and thoroughly cleaned housings and checked that fuses were seated all the way....some pressed down for a firmer connection.... Pic #2... lower circle was cleaned and repaired....upper circle looks like the conduit has disintegrated from years of heat cycles....I am assuming.... Pic #3...lower circle repaired.... Pic #4...haven't checked the FSM... anyone have an idea of what part this is....could it be a relay??? Pic #5...positive battery ground location....cleanup is in order...little bit of corrosion going on there... Pic #6...negative battery groung...looks like the washer is part of the end connection....20201101_125938.jpg20201101_190232.jpg20201101_135307.jpg20201101_191810.jpg20201101_142932.jpg20201101_143008.jpg Sent from my SM-G981U using ZR-1 Net Registry mobile app
