Old 09-29-2009   #41
VetteMed
Default Re: Silicone or rubber hoses
Originally Posted by Pete View Post
Both, Rad and F hoses
If i had to choose.
The more important is the F hose.
If one really needed rad hoses they are available from Samco.
The F hose is not available for poor people
Lee you'll be making both pieces lower/upper F hoses
Pete
I'd like rad hoses, since I don't like the Samco lettering all over everything.
Old 09-29-2009   #42
QB93Z
QB93Z's Avatar
Jim are you still driving the hell out of your car? I need a test vehicle for the PCV hoses. These might be a go.
Yes I am. As often as I can, as much as I can.
I would be glad to test a set for you.
If I were to go after a group of hoses....ie; PCV vs Coolant is there a preference. I am looking at the F-hose at possibly $20 per if shipping is not a roadblock. Keep in mind I have only been given quotes and the product needs to be decent.
I would like to see you produce both the coolant hose set and the PCV hose (F-hose?) set. My priority would be the radiator hose set without the Samco name all over them.
Old 10-01-2009   #43
Initial info, the hoses will be made of NBR...here is some info on the material:
http://www.iisrp.com/WebPolymers/07NBR-18Feb2002.pdf
This appears to be a common material used to make hoses and is good from -100 degrees to 260 degrees and withstands 6 bar of pressure or 87 PSI. I think these would be sufficient for our application. From my research Gates hoses are good to 275 degrees. Samcos, due to the reinforcement material, are good to 356 degrees.
This company does supply hoses to aftermarket companies, including one based in New Jersey
Let me know your thoughts
Old 10-01-2009   #44
VetteMed
Seeing as 275 degrees is going to cook the motor anyway, I don't see why a hose needs to withstand anything higher than that anyway. Someone correct me if I'm wrong?
Old 10-01-2009   #45
Consistent with Goodyear standards
http://www.goodyearep.com/productsdetail.aspx?id=6106
Old 10-02-2009   #46
QB93Z
QB93Z's Avatar
Lee, do you know what the stock LT5 coolant hoses were made with? I believe that they are reinforced hoses. Is it possible to get one of the standard automobile coolant hose makers to make standard hoses in the LT5 shapes and lengths?
Thanks for your work on this.
Old 10-02-2009   #47
They told me they copy the sample with regard to reinforcement.
Old 10-07-2009   #48
Hoses samples are on there way
-PCV elbows(2)
-F-Tube
-PCV cap
-the 90 rubber tube for the plenum.
Lets hope they get there!
I am hoping to put this togther as a package for the low low price of $60-70 per set. Thats not one, not two but fives hoses for less than the price of one. Does that sounds fair?
Old 10-07-2009   #49
secondchance
-PCV elbows(2)
-F-Tube
-PCV cap
Now, that's a deal! I spent $370 (albeit silicone version) or so from you know who...
Old 10-07-2009   #50
tccrab
tccrab's Avatar
And I just spent $95 on the group buy.
It was a pretty darn good deal (until now...).
*sigh*
TomC
"Crabs"
