Old 03-24-2011   #41
Default Re: Ready for the oil catch can...
here is what was listed on the invoice
CCAN:Clear Clear - PCV Oil Catch Can and Hardware
I think it was the cheaper LS1 (C5) version I bought)
Old 03-24-2011   #42
Im thinking black or silver with chrome fittings for mine. Really thinking hard about the chrome as well. And I agree I really like the look of Jeffs engine. Mega clean and a great color.
Old 03-24-2011   #43
I dunno It more metalic silver flake from being PCed. I already have several Carter bling items and billet items in there. My concern with the chrome is scratching the crap out of it during the install. I just installed more stainless bolts from Jerry last night (Map Sensor cover, TPI Cover and Top of the air Horn. Dont know how I missed those the first go around. I love Jeffs setup thats the direction I am going plumming wise. Any other locations out there over folks are using??? Jeff looks logical for a FY 90-91 car but I wonder what the ASR equipped folks have come up with yet. Jeff how much do you catch in the catch can per lets say month?? GC
Old 03-24-2011   #44
I have a bad example as I had the large IH PCV holes and Larger Cyl Head holes which is a no-no..
This year will be a better judge of oil in the can.. although it was not that much per month.
Old 03-24-2011   #45
Based on that Jeff is this mod worth it? Yeah now I remember... your running the later plenum right?
Old 03-24-2011   #46
Correct.. Later Plenum and IH.. not sure if it is worth it or not .. hopefully others may know, but if it catches some then that is less going through the motor
Old 03-24-2011   #47
mike100
I might order the LS3 one, because if I find something better for the 91, then I can always use it on the '08. I wonder if they supply a length of hose?
Old 03-24-2011   #48
Aurora40
Aurora40's Avatar
If you have pulled your plenum and had oil run out of it, it is worth it. My plenum was dry afterwards.
You can also likely see this as KR on the first couple hard pulls if you scan your car.
Old 03-24-2011   #49
Alberta_ZR1
Definitely a nice addition to have. I like how Jeff ran it on his.
Now I wonder if they ship to Canada
Wonder how the hoses would look with steel braid skin and imitation high pressure hose ends.
Steel Braid Hose Kit
Available with chrome fittings
I know you can order particular sleeve sizes and clamps without having to buy the entire kit.
Alberta_ZR1 is offline   Reply With Quote
Old 03-24-2011   #50
Alberta_ZR1
I will just make up some 6 AN Aeroquip hydraulic SS braided hydraulic hose with reusable fittings from Summit Racing
Definitely the proper way to go, but the best I could do is purchase pre-made hoses, don't have the resources to build my own.
