Old 04-18-2009   #41
Default Re: Car back to running like sh!#
Well I started with addressing anything recently changed......as there is a known issue with some coils, went there first. Pumps second, as I had put a slightly used one in when addressing the code 55, which later showed to be a code 64. Most people were set on needing a new set of injectors, but ultimately with this issue no money spent in tracking down the problem.
With regard to the O2 I did open the fuel filter and it looked fresh...so pretty sure O2 was shot.
Old 04-18-2009   #42
Well maybe I spoke to soon, went out problem had the issue again to a lesser degree and then gone....ran the car for awhile after and no issues...hmmmmmmm
When I got back put a fresh vac line to the MAP, and new PCV valves.
Old 04-18-2009   #43
Ccmano
Sounds like your in the right neighborhood, at least.
H
Old 04-18-2009   #44
Done for now, its runs.....getting the plate tags for the 92...time to get it out.
For tonight.......going to sit back and drinks a few Beers.
I can now remove a plenum and change the coils in less than 2hrs(that included trying to Ohm them)....also have the fuel pump swap down to about 35 minutes
Jerry's gaskets have held up well.......on and off 2X and no rips
Old 04-18-2009   #45
Yes BTDT. After reading a number of threads just like this,
I would recommend, to anyone, investing in a scantool and avoid wasted hours (years) and dollars. Pays for itself many times over and in many different ways. If =Jeff= gets the .adx done for ScannerPro you'd have a pretty inexpensive tool. JMO
Old 04-18-2009   #46
Dom outline what we would need:
Operating system? I've only got Vista on my home computer
Software?
Equipment?
I think many would be interested
Old 04-18-2009   #47
Software?
Equipment?
1. Laptop - Could be running DOS or XP or Vista. Mine uses XP. Depends on the scantool. I just bought a 8.9" Acer for $300 at Costco with XPHome.
2. Scantool - EASE if you can find the personal version. XP
Datamaster TTS. XP
Diacom. DOS
ScannerPro - XP =Jeff= can tell us if they have the CCM
sleep issue resolved. Also need the .adx file for your
year ZR. He's building the .adx for the AYBK 90 BC
3. ALDL cable - like this one http://cgi.ebay.com/ebaymotors/GM-AL...4506.m20.l1116
You can also build your own.
4. Power Inverter - Personal preference but laptop batteries never last long enough. I have an RS inverter with 2 outlets @ 120v from the cigarette lighter.
Old 04-18-2009   #48
ScannerPro Sleep issue? first I have heard of it
I have an ADX.. mostly complete should be somewhat usable I think
Old 04-18-2009   #49
If I am running Vista, what can I use?
Old 04-18-2009   #50
ScannerPro I think will work, Ease will not
datamaster might
