Old 01-31-2009   #41
tpepmeie
Default Re: (reground) cam went flat?
Originally Posted by jonszr1 View Post
stk spring pressures are76-84 closed and 194-206 open .just another reason our engines rev fast . alot easier controlling 4 small valves than 2 big sobs
Brad, have you measured this? How do those numbers square with what is on the zr1net site (from HOTB):
VALVE SPRINGS
YEARS 1990-92 1993-1995
Type Inner & outer opposed winding Same
Load-Closed 160-313 N (36-70 lbs.) Same
Load-Open 350-696 N (78-157 lbs.) Same
Supplier Tempered Spring Same
Old 01-31-2009   #42
jonszr1
jonszr1's Avatar
a buddy of mine used those figures to set up the springs in my blk car. he said he got those figures from the fsm .i just cked and it is what the fsm says they should be .unless i am reading things wrong .which the way my day is going is entirely possible
Old 01-31-2009   #43
tpepmeie
I've got my FSM in hand, but not seeing those numbers...
has anybody actually tested the stock springs?
Todd
