Old 04-10-2023   #41
TallySpeedRacer
Default Re: FS Single fuel pump conversion for LT5
I'll take one, what do I need to send you?
Andre'
TallySpeedRacer is offline   Reply With Quote
Old 04-10-2023   #42
Flyman 27
Flyman 27's Avatar
PM sent
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 09-30-2023   #43
ws6ta444
I would like one of these, how do we order one?
ws6ta444 is offline   Reply With Quote
Old 09-30-2023   #44
Flyman 27
Flyman 27's Avatar
PM sent
Cams by Pete
Old 09-30-2023   #45
ws6ta444
thank you, I will be ordering from you
Old 10-19-2023   #46
Domestic Power
Domestic Power's Avatar
Hi Dan,
Could you send me a PM on how to order your kit ?
Thanks in advance !
1990 Steel Blue #2818 ( stock for now )
Domestic Power is offline   Reply With Quote
Old 12-11-2023   #47
Bristowb1
Hi Dan how do I order?
Bristowb1 is offline   Reply With Quote
Old 12-11-2023   #48
Flyman 27
Flyman 27's Avatar
I sell on ebay, it's the easiest way.
https://www.ebay.com/itm/166458203967
Cams by Pete
Old 01-18-2024   #49
TallySpeedRacer
I installed one of your fuel pump conversions last year which ran well for 6 months or so. I I currently have a fuel pressure issue which kicks me out of full power due to low pressure (code 61, lean). The idle pressure is showing 38 psi, thinking it should be around 47-48. Have you any idea what the problem may be other than a faulty pump?
Andre'
Old 01-18-2024   #50
Flyman 27
Flyman 27's Avatar
1) Using the connector plug under the hood at the harness can you check the amperage being pulled by the pumps? At idle & rpms?
2) Did you change both the relays when you changed the pump? Sometimes they are worn & won't pull full amperage.
3) Idle pressure should be around 43PSI give or take a little.
4) Also, pull the vacuum hose off the fuel pressure regulator & see if you smell gas, if so, your regulator may have failed.
Please let me know what you find.
Dan
Cams by Pete
