#41 |
![]() Join Date: Apr 2004
Great job congrats...
#42 |
Nice work, I'm anxious to see how she performs with the fuel pump mod. It's the first, aside from the ones Haibeck has done, I've seen.
H ![]() |
#43 |
![]() Join Date: Jul 2007
Got a link for the South Bay injectors?
#44 |
![]() Join Date: Jun 2020
So the car is purring like a kitten but, I couldn't drive her because the clutch and brakes weren't functional. I ended up having to replace:
*Clutch mater *Clutch Slave *Clutch pressure line *Brake Master Once I had all the hydraulics working, I could finally take the car on her maiden voyage! Car drove well, but when I would get into high RPM, it would cut out like it was losing fuel. It did this whether I was in full power mode or not, so I knew it wasn't the secondaries. First step was to rent a fuel pressure gauge with a long enough hose to tape to my windshield and watch what was happening under load. After one pull it quickly became apparent that the car was running out of fuel in high RPM. A 255 pump can certainly handle the fueling requirements for this car, so what was going on with my new fuel pump? Well, Walbros are sold out due to Covid so I bought a Quantum off Amazon... I've used this brand before, and it was unusually cheaper on Amazon than their website. I must of gotten a knock off or incorrectly sent stock LPH pump! So I ordered the Racetronix 255 with the C4 install kit after some research The Racetronix C4 install kit is impressive, nice hardware and wiring! I installed it tonight and took the car for a spin after thoroughly warming her up: RUNS LIKE A BAT OUT OF HELL!!!!!! WOW! The engine just screams to redline, and the Corsa exhaust is just music to my ears! I'm head over heels in love with her, and can't wait to get some dry weather and tear up the back roads! |
#45 | |
I actually emailed Marc and discussed his mod with him last week (he's a great guy btw!) , and showed him some wiring adapters on Racetronix vs soldering pump #2 into a Y with #1. Marc said soldering them into a Y is the only way they can handle the increased voltage from the aftermarket pumps. I showed him pictures of how I did it, and he said that's the right way to do it! So anyone with trashed double fuel pump senders, is now good to go thanks to Marc Haibeck! |
#46 |
Jeff,
Below is the link for South Bay injectors. They are re manufactured and flow tested Bosch injectors. I called the owner and spoke with him, and he said he sells a lot and has never had a set sent back. I tested mine on my buddies flow bench, and they were flawless! https://www.southbayfuelinjectors.co...ctors?___SID=U |
#47 |
![]() Join Date: Nov 2007
Fascinating saga! I've been following your progress - not jumping in as you were in good hands throughout, and great to bring her back to life!
As I read through, I just have a couple items:
Well, with all that said, Welcome to the BROTHERHOOD OF THE BEAST! P. |
#48 | |
![]() Join Date: Jul 2017
Sent from my SM-N920V using ZR-1 Net Registry mobile app
1990 Black/Black ZR-1 #1155 1993 White/Red coupe (Regrettably sold) ![]() |
#49 | |
#50 |
Thanks! This car sure is addictive to drive! Next up is going to be a full detail, paint correction, and recharge the AC!
