#41 | |
![]() I think the Pilot bearing (needle bearing) comes pretty well packed with grease already ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-03-2021 at 01:45 AM. |
#42 |
![]() Join Date: Jan 2006
As a PSA the 94-96 manual leather shifts boots have been out of stock everywhere, new shipment just came in at the end of December, I got mine last Friday, got the transmission install finished yesterday and went to swap shift boot on my shift plate and mine at least (probable whole run) came in with the boot glued to the metal frame that attaches to the bottom of the shift plate backwards... can't shift to forward gears, I was lucky enough, not that it is that big of a job to quickly notice this, I removed the leather from the supplied metal mounting plate and turned it around and glued it and left it in small clamps overnight and installed it today....now it is right. Usually when this happens there is usually one run of production that goes to all the Corvette parts sellers
#43 |
Short test drive to check transmission tonight, header only waiting on a few small parts for custom exhaust. Man was it loud but with the new Prothane Motor Mounts, NOS Blue Tag, new pilot bearing and throw out bearing new clutch master and slave...ZERO , actually less than zero play or movement in drivetrain or shifter, I have stock PROM in it as I am awaiting my updated PROM from Haibeck any day, but it breaks the tires loose in third gear with just the headers. WOW! I wasn't in a residential zone but the exhaust sound vibrated the console. It was cool and best of all transmission install successful thanks for all the transmission help!
#44 |
![]() Join Date: Jan 2009
curious about the prothane motor mounts. what part number is it? any pics?
thanks John |
#45 |
The Prothane mounts are solid billet aluminum with a rubber cushion. I do have pics of the entire restoration I will be posting soon. I have pics of the mounts with my custom heat shields.. Will try to get a pic posted.
#46 | |
H ![]()
#47 |
Mainly because of heat , the can stand up to header temperatures plus it gives more room to O2 connectors and I made heat shields for them to look like OEM. I also like the more connected feeling and less weight transfer. The have rubber dampers on the bottom. I think they will be fine. When I get the new exhaust on and drive , I will be issuing a thorough report on a lot of items.
