Old 10-15-2019   #41
abull1499
Default Re: Bought One
All good tips. Thanks for the advice. Not sure on the CCA because I didn't replace the battery, it was the previous owner. I'll check that out. I haven't had a chance to start the car back up yet, but I'll give it a shot tonight.
One thing that was odd was it looked as though the plastic around the battery terminals had been removed or cut off? The terminal nut is just exposed on both pos and neg. I'll take a picture if I have time tonight.
abull1499 is offline   Reply With Quote
Old 10-15-2019   #42
Sounds like at some point the top of the battery nuts were striped and they took the easy way out in replacing them.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-15-2019   #43
With a no start issue in a 91 most likely the relay. I did a thread on the other Z site explaining the process of installing a second starter relay. My car car several no start episodes,installed the secondary relay and haven’t had any issues since.
Old 10-15-2019   #44
abull1499
Yes, I plan on having Haibeck do that for me. But given the car jump started on first attempt, wouldn’t that indicate battery issue and not relay?
Old 10-16-2019   #45
No necessarily,from what I understand the electrical circuit for the starter was a poor design and was revised in 1993 I believe. The jump start gave the circuit an extra jolt and that’s why it started.
Old 10-21-2019   #46
abull1499
Finally had a chance to fire up the 91 this weekend after the no start/jump start incident from last weekend.
She fired up no problem and I drove around town for 5 miles or so with a pit stop for coffee. No issues starting up at all. Haven't had a chance to check the battery load, etc.
Could it still be the relay that caused the no start last week or more likely a low battery?
Old 10-21-2019   #47
The no start issue is random and can happen anytime. In the past I had maybe 5 times where the car wouldn’t start,installed the relay problem gone.
Old 10-21-2019   #48
abull1499
Gotcha. I’ll get that done then. Thanks for the help!
Old 10-21-2019   #49
I’m in the process of transferring my STARTER RELAY MOD from the other forum to this one once I figure out how to post pictures again. I dropped PHOTO BUCKET,started using INGUR abit now they’ve changed their format.
