Old 10-29-2019   #41
Ccmano
Default Re: WTS 90’ LT5 Engine Part out
Thank you for your purchase Paul...
H
[B]90'ZR-1[/B] #1461 Red/Black
[B]08 C6 Z51[/B] Crystal Red Metallic Sold Vararam Intake, Tune, Sold
[B]05 C6 Z51[/B] Red/Black Sold
[B]90'ZR-1[/B] #1723 Black/Gray Sold but not forgotten
[B]91' Z51 L98[/B] White Vert. My First, you always remember your first. Sold.
Old 10-30-2019   #42
Subfixer
Subfixer's Avatar
What happened to the rest of the engine?
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 10-30-2019   #43
Ccmano
The “Long Block” was sold to the German Racing team that campaigns the LT5 powered Opel Kadet hill climb car. Hovemann Racing. It will be rebuilt into their backup engine. Everything else was or is being sold here. The only major piece left is the transmission.
H
Old 10-31-2019   #44
Subfixer
Subfixer's Avatar
H
That's a cool place for that long block to end up.
Old 11-12-2019   #45
Ccmano
TTT Make offers...
H
Old 12-04-2019   #46
Ccmano
Back to regular price but feel free to make an offer.
H
Old 12-04-2019   #47
JMO343
PM sent.
JMO343 is offline   Reply With Quote
Old 03-27-2023   #48
2poor4aZR1
Any parts left or available? I have some odds and ends I'd like to grab if you still have them.
2poor4aZR1 is offline   Reply With Quote
Old 03-27-2023   #49
Ccmano
Here's what's left....
Half price if you want it all or make offer.
*Injector Housing bolt set. $25
*Throttle body bolt set $25
*MAP Sensor with plenum bracket $55
*Secondary throttle plate arms, washers, nuts set $79
*Secondary linkages and mounting brackets with bolts $65
*AC compressor, functional, no clutch $129
*IAC Motor $25
*Intake air temp sensor $25
*[B]Both under plenum water temp sensors $35
*Drive shaft with the yoke attached $149
*Cam cover vent line 1 driver side available $20 ea.
*2 Flywheel bolt sets $39 ea
*2 New Knock Modules (90 only) $99 ea.
*Power steering bracket with bolts $39
*Right and left engine mount brackets with bolts $70
*Vacuum line keeper with bolts, mounts to PS reservoir $35
*1 set ground bolts to top of bellhousing $25
*1 set Bell housing mounting bolts $39
*1 set DIS Module mounting bolts $20
*1 set oil filter housing mounting bolts $20
*Engine Wiring Harness Loom $20
*Bell housing inspection cover $20
*transmission exhaust system hanger $20
*Clutch fork and pivot $50
*1 set fuel injector clips $10
Old 03-31-2023   #50
G8nightman
G8nightman's Avatar
Pic of MDPS Sensor with the ECM bracket?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
