#41 |
![]() Join Date: Apr 2013
#42 |
Bit off topic but thought you might enjoy this .
Kid puts me to shame with his mechanical skills and he can get to the tight spots easy lol . One lucky boy to be working on a ZR-1 so young . https://www.youtube.com/watch?v=pXWg84w98l4 Last edited by Tripler; 07-01-2019 at 10:27 AM. |
#43 | |
H ![]() |
#44 |
Hi Mike,
How did you go sorting your Ruff Idle, loss of power issue? Have experienced this multiple times. Cheers |
#45 | |
Just got off the phone with Marc Haibeck and ordered the DVD plenum pull video and the throttle body bypass tube . Since I am draining the car by 2 litres as per Marc's instructions , I may as well install the bypass . Also when talking to Marc and I told him what the car was doing he told me I did not have to tell him anymore info as it is definitely the FPR . Been in contact with Phil also and once I get the FPR out I will mail it to Phil to be modded . Looks like this will be a month or 2 process but the beast will run again . Also have to call Jerry's Gaskets and order new o rings for the injectors . FPR . Mike Last edited by Tripler; 07-08-2019 at 08:43 AM. |
#46 | |
Thanks Mike |
#47 | |
and it stays at 48 psi . I did not start the engine ,only with key on . Thanks Mike . |
#48 | |
Tight fit but I was able to attach a fuel pressure gauge . With key on , pressure held at 48 psi for 3 minutes or so . Thanks Mike |
#49 |
Added some lighting to do the operation . Be going in next week .
Plenum, Injectors , FPR removal ![]() ![]() ![]() Sent from my ASUS_X00PD using Tapatalk |
#50 |
Found an interesting way to drain the plenum , unless some of you guys already have done this . I hooked a small hose to the glycol fluid tube at the lowest point of the plenum towards the firewall on the right side . Then the fluid will automatically syphon out into a lower point , in this case , a measured dish for 2 litres marked so I knew how much I removed . Obviously radiator fill cap is removed or open. You will hear the fluid syphon out and just watch your fill dish level and pinch off the the hose or remove it and voila, no fluid in the plenum .
I tried using a mechanical way to suck out the glycol , but nothing was happening so then tried the hose trick and that worked great . ![]() ![]() Sent from my ASUS_X00PD using Tapatalk Last edited by Tripler; 08-15-2019 at 08:34 AM. |
