Old 06-03-2019   #41
HAWAIIZR-1's Avatar
Default Pulley Failure
Originally Posted by Locobob View Post
Hahaha yeah this isn't the first time the modding disease has bit me in the ***, and it probably won't be the last. I am a little more cautious now about making non stock "improvements" though.
Hey Robert,
There are a few of us on here that just won’t leave sh#t alone even if it’s working fine.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 06-05-2019   #42
Default Re: Pulley Failure
Hey Robert,
Attachment 9708
I have decided to replace all of my Aluminum Belt Tensioner Pulleys with New Stock Belt Tensioner Pulleys.
This in spite of the fact that Jim had a Stock Pulley Cut in half by the Serpentine Belt at 60,000 miles
I use a ratcheting 18mm Box combination wrench (no angle on ratcheting end and since combination I can use another box wrench on open end for leverage).
I can now replace that Belt Tensioner in 10 min more or less (without removing anything else).
I lift the Belt Tensioner (flipping it 180 deg) up between the Alternator pulley and coolant pipe crossover
I use a 14 mm wrench for the Pulley bolt itself.
I do NOT do this job when engine is HOT
Old 06-05-2019   #43
HAWAIIZR-1's Avatar
I have decided to replace all of my Aluminum Belt Tensioner Pulleys with New Stock Belt Tensioner Pulleys even though Jim had a Stock Pulley Cut in half by the Serpentine Belt
So is this the official recall of the aluminum belt tensioner pulleys? LOL!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 06-05-2019   #44
Yes......No recall on Aluminum Water Pump Pulley (which has no Belt Guides and very easy to slip Serpentine Belt off), Aluminum Power Steering pulley, or the Aluminum Alternator Pulley.....Just the Aluminum Belt Tensioner Pulley Recall
Old 06-05-2019   #45
HAWAIIZR-1's Avatar
Yes......No recall on Aluminum Water Pump Pulley (whcih has no Belt Guides and very easy to slip Serpentine Belt off), Aluminum Power Steering pulley, or the Aluminum Alternator Pulley.....Just the Aluminum Belt Tensioner Pulley Recall
Okay, I’ll replace mine at the next opportunity too before the UPR CCC (Cheap Chinese Crap....as they call it in Mustang forums) blows up! LOL!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 06-05-2019   #46
Locobob
I have a new Gates tensioner pulley and belt installed now. I went off Craigs info on the belt size but I found the Gates 815 belt to be a little loose... like I didn't even have to fight to get it on. So I went one size smaller and found the Gates 810 to be a better fit. This is with SRP underdrive pulleys btw, if you have stock pulleys disregard the belt info.
Robert
Old 06-05-2019   #47
HAWAIIZR-1's Avatar
Robert,
Good to hear progress. Sorry if wrong info was given to me years ago when I bought SRP pulleys from Randy. He is straight with info. Be sure your tensioner itself is okay. I still have the cover of the belt I was provided and it was a correct fit. Also double check the part number on the belt itself. Sorry, I'm sure you already know all this.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 06-06-2019   #48
Locobob
Robert,
I don't think its a question of Randys list being wrong. I used a Gates belt that was not on the list based on it being an 815 like the Dayco listed. The last three digits on the belt part number are often the belts length in inches... so 815 should be 81.5 inches. In this case I found the .5in shorter Gates 810 to be a better fit.
Robert
Old 06-06-2019   #49
HAWAIIZR-1's Avatar
I agree with you about the numbering system on drive belts and measurement. Glad to hear you got it sorted out and best wishes going forward. I’ll replace mine too before any issues. Thanks again for posting. 🤙🏼
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 04-07-2023   #50
2poor4aZR1
Old thread, but want to say thank you for posting pictures of the back of the tensioner. You'd be surprised how hard it was to find a picture of what the back of the tensioner looks like.
2poor4aZR1 is offline   Reply With Quote
