Old 05-08-2019   #41
Default Re: Code 41 = new ECM?
Originally Posted by Weeberone View Post
Yes, under category 1 I get a C12 then the 3 dashes - - - then under category 4 I get H41 then the 3 dashes - - -.
To you, that indicates a healthy ECM?
C refers to CURRENT Codes
H refers to HISTORY Codes
I think you have no active codes.. if it was a C41, then I would be a bit more concerned..
What are the symptoms you are seeing?
Old 05-08-2019   #42
So the 90’s show ECM malf codes on the cluster not the DIC?
Old 05-08-2019   #43
Both, depends how you are checking it..
Old 05-08-2019   #44
Weeberone
Does it matter if it’s running or not? I check with it not running.
When it is running it idles at about 2000 rpm and stumbles and dies if you try to drive.
Weeberone is offline   Reply With Quote
Old 05-08-2019   #45
C41 will not cause a stumble and die.. I did a 1991 dash in a 1989 and tried to use a 1992 CCM, it would not work and I had a Code 41 (Active) but yet i could drive the car.. no issues
I ended up with a 1991 CCM to fix the issue, however.. I think you are looking in the wrong spot for the issue you are having
Old 05-08-2019   #46
Ccmano
We are focused on the ECM and Memcal here, but these symptoms sound an awful lot like a vacuum line off on the MAP sensor or even a bad MAP sensor. Have you checked the MAP sensors?
H
Old 05-08-2019   #47
Well if its an ECM MALF then it would cause the issue he is experiencing.
Basically its defaulting to limp home mode.
Old 05-08-2019   #48
It's not.. he sadi Module 1 is C12 ( that is ECM
Module 4 is H41, that is CCM
HE has another issue, not ECM related in my opinion..
Old 05-08-2019   #49
Weeberone
I thought module 4 was ECM as it reads “Err” when not communicating with the CCM, which it was doing when this started. That went away after cleaning contacts.
The vacuum hose is still attached to the MAP sensor.
Old 05-08-2019   #50
just checked the FSM.. yes.. 1 is CCm 4 is ECM
Error is 41 Cylinder Select
see diagnostic pages attached
