Old 08-21-2018   #41
ChattanoogaJSB
Default Re: Introduction and Overheating (long)
Originally Posted by rkreigh View Post
the orange dexcool stuff is bad news for the lt5 head gaskets and I would get rid of it
run the green stuff, you'll be glad you did.
Yes, we have fresh green in it and now believe it has had green in previously
ChattanoogaJSB is offline   Reply With Quote
Old 08-21-2018   #42
rkreigh
fyi,
I was shocked, after about 4 years and 30k miles a brand new radiator was about 40% packed with crud.
the bigger ron davis seemed to clean up easier than the stocker, but I was surprised just how dirty it was after that amount of miles from normal highway use.
95 390 LPE ZR1 (505 rwhp)
Old 08-22-2018   #43
ChattanoogaJSB
fyi,
It’s definitely on my mind that it could be restricted. Certainly would explain heating up under load on only.
Weather has improved and I’m going to test drive it today using the lcd temp readout and will report back. The chip is a no brainer whether I need to put a radiator in now or not.
Thank you for the reply!
Old 08-22-2018   #44
My '93 was getting a bit hot at about 40,000 miles. I had my mechanic remove the radiator and it turned out to be about 40% plugged with debris. He hosed it out and replaced it; I added a 1/4 inch hardware cloth mesh screen to the air opening underneath and never had a problem again. Also had Marc add a screen to the '95 just in case. Never had to install an aftermarket radiator. This is simply a problem with the bottom feeders.--Bob
Old 08-23-2018   #45
ssrszz4
The stock radiator is junk if you ever take it out replace it with a better radiator money well spent.
ssrszz4 is offline   Reply With Quote
Old 08-23-2018   #46
ChattanoogaJSB
A couple more folks have responded and I didn’t want to be too long between visits here because I appreciate the feedback. I’ll reply tonight with the notes from my voice memo I made yesterday testing the system after the burp.
The short- short version isthe car drove beautifully and thanks to everyone’s help here could be said to cool “as designed.”
The data might be handy for someone later on so I’ll post.
Owner will do the Haibeck chip now and the radiator as a good precaution in a month or so as we have time between my projects and his two.
Probably Dewitts. No one on the c1/c2 forum has anything but high praise for them.
Benton
Old 08-23-2018   #47
ChattanoogaJSB
Here are my note of temperature based on where I am on the drive and some notes on condition. Pardon my handwriting.
I feel with everyone’s help I have a much better understanding of the cooling system and it’s next upgrades- my thanks again and for the warm welcome.
I started on one mountain, ran down, down the valley road and back up the other. The climbs are only about 1,000’ so not huge but significant
Old 08-23-2018   #48
Ccmano
Ccmano's Avatar
Very nice documentation. I see no issues here whatsoever. I see your ambient temp was 82’, keep in mind as ambient temps rise so will your engine temp. Enjoy your Z. When the Haibeck chip is in you will enjoy it even more.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 08-23-2018   #49
ChattanoogaJSB
H
Absolutely. We routinely see 15 degrees hotter weather for a period in summer.
Haibeck will be welcome.
Guess I need to find my own Z now...but where to put it?
