Old 08-15-2018   #41
Default Re: Building a beast...doing a 391
Nice work by Dr. Greekenstein.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-22-2018   #42
Nacho_ZR1
Originally Posted by EvanZR1 View Post
Car is off to Pete's.
Hi Evan! Longtime no speak GORGEOUS SteelBlue! That was always my fave color on the Z's!
Good luck with the build and I will be subscribed to this thread watching your progress
-Carlos
[B][U]---SOLD BUT NOT FORGOTTEN---[/U][/B]
[SIZE="1"][SIZE="2"]1992 ZR-1 #483
[COLOR="DarkRed"]Dark Red Metallic[/COLOR]
[U][B]Mods[/B][/U]
-Jeal headers
-Stock exhaust with X-pipe
-4.30 Gears
-Corey Henderson tune
-375 RWHP[/SIZE][/SIZE]
Nacho_ZR1 is offline   Reply With Quote
Old 08-24-2018   #43
EvanZR1
EvanZR1's Avatar
Motor is assembled and going in:
Pete also started tearing down the old engine, and turns out it wasn't a head gasket. Said it it looked like it swallowed a worm clamp. His guess is someone left one sitting somewhere when doing maintenance at some point in the past and it got sucked in and probably sat in the intake manifold, then finally worked it's way into #6 cylinder. Cracked the liner, bent the valves and damaged one of the cams. Would certainly explain why it wasn't running well.
Evan
2024 Z06
SOLD - 1991 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1
EvanZR1 is offline   Reply With Quote
Old 09-04-2018   #44
EvanZR1
EvanZR1's Avatar
Motor is back in the car and running:
But of course nothing goes smoothly, Pete said the voltage was dropping the longer the car runs, so time for a new alternator. Also waiting on shocks to come back from being machined to fit coil overs. Few other minor issues to fix once all that's done, but it's getting closer.
Pete also fixed the fit of the exhaust:
Previous:
Fixed:
Evan
2024 Z06
Old 09-04-2018   #45
JThomas
JThomas's Avatar
You are getting her dialed in.
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 09-04-2018   #46
Dr. Greekenstein does good work.
Old 09-04-2018   #47
Nacho_ZR1
Lookin gorgeous! And your car will be ready just in time for the Texas Mile Shootout happening Oct. 26-28 in Victoria TX
https://www.theusmileracing.com/dates-and-schedules/
[U][B]Mods[/B][/U]
-Jeal headers
-4.30 Gears
Old 09-20-2018   #48
EvanZR1
EvanZR1's Avatar
No new pics but a few updates:
  • First off, the alternator was putting out low voltage, so that had to be replaced.
  • Next up, the new stainless FIC injectors that were put in by the previous owner were not performing properly. Car would not idle properly and wasn't getting enough fuel. Pete put in Accels for the primaries and a low mileage set of 94 injectors he had available for the secondaries and it's now running great.
  • Still waiting on shocks to come back from being machined for DRM coilovers
  • Turns out the seats that were put in as part of interior restoration were 1990 seats. Problem is that 1990 seats used power recline adjusters, so Pete had to do a custom wiring job to get that to work. So I can now adjust recline and side bolsters, which is very important to me as most people recline the seat too far for proper driving position.
  • Dash cluster has been pulled to be sent out for rebuild (tach was way off and LCD was dim).
So things are moving along well, and I can see the light at the end of the tunnel.
Evan
2024 Z06
Old 09-20-2018   #49
JThomas
JThomas's Avatar
Wow! Keep at it, it will be running and turning great times in no time!
Joe Thomas
Old 09-21-2018   #50
Flyman 27
Flyman 27's Avatar
That engine is a beauty alright!
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
