03-12-2018 | #41 |
Re: Hunting idle issue
Oh... You just ruined my evening. I'll keep searching then.
03-13-2018 | #42 |
03-15-2018 | #43 |
Can’t tell from the video. There’s a leak somewhere just keep at it.
H
03-15-2018 | #44 | |
I feel bad. 5 pages... Maybe I should type less and work more. Problem was pretty much impossible to see with the plenum still on... But when I removed it, it was pretty simple. Marc Haibeck says on his awesome vacuum leaks PDF that GM added a clamp on that "rubber connector" after '91. However, I went to get the part number of that clamp to GM and they showed me the diagram of a '92. There is no clamp. Anyway, problem seems to be solved now. However, vacuum pump still turns on every 15 seconds or so. Haven't really tested the car on the road, it's winter here. |
03-15-2018 | #45 |
This is a major reason of why we dump the secondaries. Besides, there's better use for that vacuum.
03-15-2018 | #46 |
Pump running every 15 seconds is fine. Haibeck says if it stops for at least a second or two there is enough vacuum back up. Good work tracking it down!
H
03-15-2018 | #47 | ||
I'm on the forums for 4 sports cars and this one here is the best, no doubt! |
03-15-2018 | #48 | |
03-15-2018 | #49 |
If I am to delete the system, I'd rather do it cleanly and remove it completely!
Mazda RX-7 1992 Chevrolet Corvette ZR-1 1991 Dodge Viper RT/10 1994 Mercedes-Benz C63 AMG 2009 |
