#41 |
With the way winter is shaping up here in Northern Virginia looks like it will be some time before I can get around to seriously road testing this fuel pressure regulator. Therefore, if anyone is interested in testing it out on their ZR-1 I will gladly provide it as no cost loaner for a reasonable period of time. Afterwards I would like it back to perform a full tear down inspection.
#42 | |
#43 |
It amazes me just how clever and smart some people are. Wow.
#44 | |
I can pull a plenum in a few minutes and install one as you like just to see how it functions. I also have one or maybe more FPRs (at least one that has failed) I removed from a ZR-1 that was flooded with gasoline. I will go and check that now. I like the mechanical looks ![]() ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-20-2018 at 08:25 PM. |
#45 |
Thanks Cliff, I’ll send it your way this weekend. Send me your failed one after this one proves out and I will incorporate any lessons learned
#46 |
Cliff,
Let start with the one I have completed so we can gain some quick experience then go from there. Work is tying me up at the moment and don’t have much free time for the next few weeks. Sent from my iPhone using ZR-1 Net Registry
#47 |
Cliff/Phil,
Let me suggest that u should add datalogging before and after installation. This way we can judge if the FPR has had any unforseen affect on fueling. |
#48 |
Cliff,
I made a suggestion. Not forcing anyone. Frankly, datalogging would represent a simpler not more complicated means of confirming results IMO. I’ve had experience with any number of “changes” that should not have affected engine operation and yet they require modifying the calibration to some extent ie changing injector brands even if they supposedly flow the same. This is exactly what I would do were I to install one of these. |
#49 | |
#50 |
Phil,
U mention that the pressure range of the 016 FPR is almost identical to the stock regulator. Can u quantify the variance or was it totally negligible? |
