Old 06-26-2017   #41
efnfast
Default Re: 1990 fog lights
Four of these lights on the roof would be the nuts!
Old 06-27-2017   #42
tf95ZR1
tf95ZR1's Avatar
Originally Posted by efnfast View Post
The fog lights are not co-operating with the high beams.
- Steve
This is what I did. It worked.
https://www.corvetteforum.com/forums...-solution.html
Old 06-27-2017   #43
efnfast
Excellent. I didn't read it all the way through, are you using the external light bulb as a resister?
Old 06-27-2017   #44
secondchance
Simplest solution I found and used on Jagdpanzer's 94 was to remove fog light relay, locate and bend the ground post so that it will not plug in and complete the circuit, solder electrical wire to the bent ground post and ground the other end of new wire to one of the bolts under the passenger side structure. If you ever want to go back to original wiring ( don't know why but...), just replace the fog light relay with a new one.
