Old 04-12-2017   #41
Default Re: Fun in the Sun @WAZOO 4/8/17
Originally Posted by dredgeguy View Post
I contacted Marc H and asked for his recommendation and he said he gets his from Rockauto. I ordered them online at rockauto.com, part number P240KC (2 needed) at $19.40 each plus $7.88 shipping so for less than $50 you get all what you need delivered. They were exact fit.
That part is not listed at rock auto
However, a google search shows it to be at rock auto..
Old 04-13-2017   #42
dredgeguy
dredgeguy's Avatar
Say hello from a former Army Red leg
ask him if he knows what
UP40FFE means
It was my personal license plate for 25 years.
I just got a response from my son Casey in the field regarding UP40FFE
He said,
Up 40 is height of burst correction for a time fuse when you observe a graze burst without a previous airburst. Time fuses are supposed to detonate 20m above target, primarily used for dismounted infantry in trench lines
Looks like he has been well trained.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 04-13-2017   #43
dredgeguy
dredgeguy's Avatar
Originally Posted by 902066 View Post
Having just put my 90 back together yesterday 4/8/17, I would be curious to know the causes of Richs high idle, and Charlie's coolant leak? Thanks for the pics, always interesting to look at. Jim
I was able to get the car up on ramps and put the cooling system under pressure. The lower radiator hose was leaking due to a loose clamp. Hopefully that takes care of the spay under the hood. If any thing else develops, will report it but so far all good.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 04-13-2017   #44
QB93Z
QB93Z's Avatar
Good news Charlie.
Old 04-13-2017   #45
nelson007
nelson007's Avatar
I thought the guy near the airport tightned the hose clips a couple of weeks ago and had solved the leaking problem? I thought you needed a water pump gasket.
Nelson
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
nelson007 is offline   Reply With Quote
Old 04-14-2017   #46
dredgeguy
dredgeguy's Avatar
Nelson
That was my concern, water pump or gasket or both but it was just the lower hose clamp. Looks like out of the 3 lose clamps, one was still not tight enough. It is now.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 04-14-2017   #47
He said,
He is correct and any FSO (Fires Support Officer) worth his salt would have learned that from OBC Officer Basic Course as a 13A out of the school house at FT Sill OK.
FFE Fire for Effects means the entire ARTILLERY Battery, Battalion, Brigade or Division would fire on those coordinates for the maximum devastating effect on the enemy. Steel rain
