#41 | |
#42 |
No.......there is coolant trapped around the cylinder liners and in other places in the engine simply because the water pump is higher than the thermostat as well as coolant trapped on ALL wetted areas of the Coolant System. The Engine coolant can only drain from a removed thermostat through the water pump. Also the inside of the radiator is not dry...it is wet and coolant still resides in an otherwise drained radiator. And....you have the Heater Core which holds coolant including the Heater hoses.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-02-2017 at 11:38 AM. |
#43 |
My experience w thermostats, Fluidyne rad, and 1/8" holes was documented
here: http://www.zr1.net/forum/showthread....ght=Thermostat My particular issue began w installation of Fluidyne and driving in colder climes. At ambient temps of anything below 55F, I could not keep temps up. The coolant temp continues to drop whenever driving. Coolant temp would increase at idle. On any drive it became necessary to cruise in 5th rather than 6th just to keep coolant temp up. Once into the summer driving season, the issue resolved itself. Some specifics. Fluidyne rad, 180F thermo w 4 1/8" holes, underdrive pulleys. I ultimately bought another stock thermo from Jerry, and put in 2. 1/8" holes. Temps at cruise stabilized at 185-190F in cold weather. Idle temps will creep up slowly but I surmise that's due to the underdrive pulleys. I think it could become an issue in the more severe driving conditions of hot, crawling traffic. Last edited by XfireZ51; 04-03-2017 at 05:18 PM. |
#44 | |
Good Morning Craig, GM 1825M is an old specification for standard, conventional green antifreeze. We recommend the Prestone Antifreeze/Coolant in the yellow jug for any application calling for that specification, but you could also use the Prime Conventional Green Antifreeze/Coolant if you want a coolant that more closely resembles the factory fluid. Please let me know if you require anything further. Sincerely, Aaron Jones Prestone Consumer Relations Representative Phone: 203-731-8191 cid:image001.png@01CDC249.2F757380 |
#45 |
I just talked to Stant and the 14068 is now discontinued. More to come.
#46 | |
![]() Join Date: May 2010
Thanks fir sharing. I'm going to check one more source here and might have to settle for this one. Now, to drill or not to drill...that is the question. Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() Last edited by HAWAIIZR-1; 04-03-2017 at 05:25 PM. |
#47 |
![]() Join Date: Mar 2014
Jerry's has them in stock according to his web site. There are units available with the gasket shown on ebay and supposedly Gates 33068 is an exact duplicate of the Stant 14068. So there are parts still available.
#48 |
The ones on ebay are not the correct ones. Ordered one and sent it back.
#49 |
Summit Racing has 180 deg Stant 14068 thermostat as does Marc......they are not in stock at Summit and will be shipped directly from manufacturer. I ordered one to test the market
![]() Sent from my iPhone using ZR-1 Net Registry |
#50 |
Funny you should mention that I did the same thing from the PepBoys online store for the Stant and the Gates version from an eBay retailer.....should be interesting.....
Sent from my SM-G935P using ZR-1 Net Registry mobile app
