08-19-2016 | #41 | ||
Re: Stuck!! No crank ! LF some input and help !
08-19-2016 | #42 | |
Roger 1990 ZR-1 #2699 Black on Black 15,000 miles Full-time secondaries, 4.10 gears, C-beam plates, ported top end |
08-20-2016 | #43 | |
I read Marc's website about narrowing down the no start. I went into the car with my multimeter and just checked one of the relays which I believe to be the starter relay (has both thick purple and yellow wires going to it) Key not in. No power to yellow. Key all the way forward (crank) and I see 12 volts on my multi meter. The purple however .. Is getting no power. Again.. No expert with nearly no experience with relays but does this mean it's narrowed down to the trigger wire on the relay? I'll have to dig my service manuals up and figure out where the wires come from but they are yellow and a yellow with a black stripe . I took a photo and marked them. Based on the relay diagram when energiZed the yellow (30) should connect to the purple(87) and voltage but I am getting none. Last edited by 5ABI VT; 07-06-2017 at 05:05 AM. |
08-20-2016 | #44 |
I would think that START ENABLE RELAY needs to be treated differently depending upon the year that has the NO CRANK - the CRANK circuit I believe is only "similar" in operation but wired very differently in the later years. OP yours is I believe a later '94 but I don't ever see you mention it.
08-20-2016 | #45 | |
08-20-2016 | #46 | |
It is obvious from this first photo that this is a 94' or 95' from the ASR (under the red milk shake) and single Throttle Cable among other things It also appears there exists an Oil Catch Can from the plumbing related to the PCV valves. On the 95' I installed my oil catch can under the Drivers Side Head Light as normally I would install the Oil Catch Can on 90' or 91' where the ASR is shown above on this 94'-95'.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-20-2016 at 12:28 PM. |
08-20-2016 | #47 | |
Not really '92+ has ASR so... BUT '93+ has the somewhat different STARTER ENABLE I believe. |
08-20-2016 | #48 |
Last night I looked again and i see that the clutch switch is wired with 2 thin wires vs what some threads and others posted about finding thicker wires. I believe this is what was changed to remove the current going through the switch in 93+ years.
I'm busy with the kids all day but hoping to get time to get a relay and I'll be free tonight to wire up the relay.. I hope ! Hopefully I can figure out which box I have my service manuals in and I can try and understand the wiring diagram better in hopes to at least pinpoint what was at fault in my situation. |
08-20-2016 | #49 |
There's your problem in the top picture...
The milkshake appears to be vanilla, the schematic in the FSM clearly calls out for chocolate... 😄 |
08-20-2016 | #50 | |
Well good news is I went to the electronics store .. They had everything but 60/80amp relays. I picked up connectors 1/4" and 3/8", ring terminals , new soldering iron (long overdue I've been using a torch but don't want to be using that near the car or other wires), a fuse wire (30a fuse rated for 40) and some other stuff. I just hope I get time tonight to get it done. |
