Old 10-07-2016   #41
RussMcB
Default Re: ECM And Ignition Module Availability/ replacement
Yeah, it's an understatement to say we're very lucky to have Jerry and his desire to keep the ZR-1 legend alive.
Old 10-07-2016   #42
Originally Posted by tpepmeie View Post
... and secondary cam chains...
You get all the credit for that Todd
Old 10-07-2016   #43
How about just an harness extension for the DIS so I don't have to break my wrist to put it back on! LOL
Old 10-07-2016   #44
Billy Mild
What happens when this module goes bad? Has anyone had one fail?
My thought would be at that point to run CNP, and use maybe an LSx computer or stand alone mega squirt to get this engine running. That seems a bit more feasible.
Old 10-07-2016   #45
I believe the majority of customers will want only to replace the failed DIS module with the least amount of alterations or modifications and keep it original in appearance, all at the lowest cost.
Old 10-07-2016   #46
Your right Jerry but that harness extension is a great idea and an improvement over original design. Regardless Jerry thanks for all you do for the LT5 community. GC
Old 10-07-2016   #47
Default ECM And Ignition Module Availability/ replacement
On my 95' when I was having trouble with INJ1 fuse blowing.....I took that harness all apart and soldered all mechanical original splices and ended up with a couple inches of additional length in the harness after retaping. Which apparently solved the INJ1 fuse issue
Besides the 8 wire connector there are 3 other connections to DIS which all gained length during retaping after soldering the splices. Each connector wiring was inserted into a 1/4 inch split loom to make sure shorted wires was not the issue.
Old 10-07-2016   #48
PhillipsLT5
PhillipsLT5's Avatar
After reading this post we should all be buying all of our parts from Jerry
Old 10-10-2016   #49
9T1 Red ZR1
9T1 Red ZR1's Avatar
I searched 19152968 and came up with a few sites that claim to have them. This number came from Marc's site as a remanufactured unit. I don't know enough about these to know if this is really what we need for the correct ECM. Is anyone familiar with what this is?
Thanks,
Bill
LT5 Red/Red
9T1 Red ZR1 is offline   Reply With Quote
Old 03-20-2017   #50
Was thinking about this today and thought it could use a bump..
Just curious on the challenges on this.. I know Jerry is working on something..
-=Jeff=- is online now   Reply With Quote
