07-25-2016 | #41 |
Re: Why I Toe/Heel-Heel/Toe
Interesting. I have always done it the first way but I can see how the second way works well for some people. The trick is applying steady smooth breaking with the middle of your foot while also stretching your toe forward to blip the throttle. Either will work with lots of practice ... I think in a larger spaced vehicle you might even be able to actually put your toe on the brake and blip the throttle with your heel as the phrase Toe/ heel suggests. I believe that's a tough one to do in a C4 ...
I will try tomorrow and let you know ... Sent from my LG-D852 using ZR-1 Net Registry mobile app |
07-26-2016 | #42 | |
07-26-2016 | #43 | |
07-26-2016 | #44 |
I'm looking forward to your detailed description of toe/heeling on bikes. :-)
07-27-2016 | #45 | |
07-27-2016 | #46 |
Actually you do a hell of a lot of toe and heel when riding a bike tho not like a car of course . Your heel is on the peg and your toes are either working the rear brake or shifter. So the phrase toe / heel really does apply to a motorcycle as well .
;-) Sent from my LG-D852 using ZR-1 Net Registry mobile app |
07-27-2016 | #47 |
Oh and yes . There are bikes with automatic transmission in case you were wondering . Google it .
07-27-2016 | #48 | |
:-) Sent from my LG-D852 using ZR-1 Net Registry mobile app |
08-02-2016 | #49 |
I remember watching races from the 80's which involves 80's turbo technology (small displacement lotsa turbo-lag) and this would force the guys to stay on the accelerator and the brake at the same time in an attempt to keep the engine loaded therefore the turbo spooled as best as possible. Certainly different than driving a N/A car.
peace Paul ZR-1 Net Registry Member #1494 |
08-02-2016 | #50 | |
