04-14-2016 | #41 | |
Re: Am I ready to install my headers?
The rep tells me LT5 needs part # 8908 which is 8mm x 1.25mm and 30mm long (underhead length). It comes with exactly 32 bolts. So should i cancel the order and get the 8905 or will these work? |
04-15-2016 | #42 | |
04-22-2016 | #43 |
I need to make some additional comments regarding the headers installation.
1: You just CAN'T install the locking tabs if you're installing the headers without removing the engine. So, it makes the Stage 8 expensive bolts pretty useless. I'm sure there's a better bolts option. 2: If you're not gonna use the locking tabs, don't put anti-seize. I just had to remove every single bolts one by one this morning, clean the threads from the anti-seize I put previously, and then put BLUE LOCTITE. Got to wait 24 hours now. |
