Old 10-04-2015   #41
secondchance
Default Re: Second time for Secondchance
I definitely want to find some brakes that fit the factory A molds for sure, but I .know it limits me. I'm thinking of selling or trading my Dymag Gen IIs, but I think the clearance is about the same as the A molds and have to measure to confirm. Thanks for the offer and take care.
Front set up I have is available with 13" rotor meant to work with OEM A mold. Rear set up I have (12.8" rotor) fits inside 11" wide A mold.
Old 10-04-2015   #42
HAWAIIZR-1's Avatar
Okay, great. Thanks Yun! I'll get with you and see what all the options are.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
HAWAIIZR-1 is online now   Reply With Quote
Old 10-05-2015   #43
Daryl,
Rear set up is from Revolution Brake LLC.
http://store.revolutionbrake.com/14-0106.html
It required some massaging to make it work including parking brake cable bracket under the car being cut/welded by 3/4" and having to shave outboard brake pad by 3/16" and adding 3/16" thick aluminum piece to shim inboard pad. Otherwise, this was the simplest parking brake solution I found and it works!
Thanks I will look into it and start saving now
Old 10-09-2015   #44
HAWAIIZR-1's Avatar
Hey Yun,
I just got off the phone with Kevin from Revolution Brakes. After your issue in 2013 the brackets were corrected with the next order. The kits from Revolution Brakes are good to go now and direct bolt on with no modifications. Great news and I'm in! He said they can also powdercoat colors for those that don't want the Wilwood black for some bling.
Thanks again!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 10-09-2015   #45
Hey Yun,
Thanks again!
That is good news because I wanted the same red calipers as I have up front. Now to save my pennies
Old 10-09-2015   #46
secondchance
Hey Yun,
Thanks again!
That's great! I'm glad to hear my feedback to Revolution Brakes actually made them improve the product.
Let me know if I can help as you move forward.
Old 10-09-2015   #47
HAWAIIZR-1's Avatar
Like GC, I have to save those pennies. Kevin sends his regards and wishes they could have fixed your issue; but he knew you are an Engineer. Like -=Jeff=- said, no mods should have to be done to a specific application kit. You are a pioneer. My problem is I think I might want to put stock wheels back on (for what reason, not sure other than to track?) so very limited and this is the best option I have seen so far. Thanks again!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 10-11-2015   #48
secondchance
October 10, 2015 update:
Phil joined us at Dempsey's and timed all 4 camshafts using degree wheel.
LT5 is almost ready to be dropped in the car.
Thanks guys!!!
Old 10-11-2015   #49
Demps
Demps's Avatar
Oh Magician Phil. I wish I had half of his talent and all of his tools. Looking good Yun!
Ted
Old 10-11-2015   #50
secondchance
Ted
What he doesn't have, he will machine it himself.
