Old 07-27-2015   #41
IMZZ
Default Re: LT5 miss at all speeds
Originally Posted by Big D View Post
IMZZ, have you done the injectors yet?
I got my injectors on Saturday. I'm trying to clean and restore everything before I put it back together. There is sure a lot of things to remember to do when putting these back together. I am trying to source a weatherpack seal that I believe was missing from previous work. I'm hoping to get it running by the weekend.
IMZZ is offline   Reply With Quote
Old 07-30-2015   #42
Johnny5
Food for thought...
After I first got my Z, it had a slight "miss" on one cylinder that wasn't so apparent under heavier throttle - if much at all. Turned out to be a burnt valve, stemming from a weak primary injector!
Just sayin.....
That's scaring me. I have to get some universals together to change the back 2 plugs and pray that it was an old plug causing it.
Johnny5 is offline   Reply With Quote
Old 07-30-2015   #43
Watch this video (go to 5:06). Some things sound familiar, maybe?
Also, very interesting comments below the video regarding the effect of oil in the throttle body.
How to Install the RX Oil Separating Catch Can System for a 2014-Corvette
Old 07-30-2015   #44
Big D
I got the swivel socket from NAPA and it works great getting the back two plugs out. It is easy with a swivel. Hope the plug is the problem.
I'm still chasing gremlins in mine. When I shoot back into the ECM, #6 injector pin is showing 86 k-ohms while the others are showing .97 - 1.0 m-ohms. Not sure if that makes a difference since I wasn't able to check to see if the injector is working; two person job and my assistant was working last weekend, one to turn over the car while I look down the injector housing to check for fuel spray.
Hopefully I will be able to check it this weekend.
By the way, anybody out there have a good schematic/diagram for the ECM, or know where I can get one? Would sure help in troubleshooting.
Big D is offline   Reply With Quote
Old 07-30-2015   #45
I'm still chasing gremlins in mine. When I shoot back into the ECM, #6 injector pin is showing 86 k-ohms while the others are showing .97 - 1.0 m-ohms. Not sure if that makes a difference since I wasn't able to check to see if the injector is working; two person job and my assistant was working last weekend, one to turn over the car while I look down the injector housing to check for fuel spray. Hopefully I will be able to check it this weekend.
Big D
69 L46/M21
90 ZR1
Not sure why you'd want a schematic. The pinouts are available in the FSM which I assume is what you really need.
Old 07-30-2015   #46
Big D
With the schematic/diagram I can trace the circuit inside the ECM to see what controls the injector and if I find that the ECM is causing my problem I can hopefully determine if the internal circuit is replaceable or repairable. W/O the schematic/diagram I haven't a clue.
Old 07-30-2015   #47
Just my opinion, but you are quite a few steps from having the ECM as the culprit.
Old 07-30-2015   #48
tccrab
tccrab's Avatar
I agree. Try not to overthink this. Re-pin the connector with the pins I sent you.
It's not totally inconceivable that you might have a bad ECM, but you won't know for sure until you fix the pins first.
I made the same mistake. Took me over 3 years, more cash than I'll ever tell wifey about, untold stress and aggravation to finally nail it down. And truth be told, I'd likely never have found it if it wasn't for this Forum.
The Brotherhood of the Beast is alive and well.
'Crabs
Old 08-03-2015   #49
IMZZ
Any luck? I finished my injector/plenum job. Everything came out OK. I just had to decide when to quit cleaning or fixing things. I wanted to be able to enjoy it this summer and remember that winter is coming.
Old 08-17-2015   #50
Johnny5
My father changed the back 2 plugs the other day and it runs great now! Not a damn problem.....except my Bose radio, lol. Did you ever find out why your LT5 is missing? I am curious.
