08-31-2015 | #41 |
Re: Brake Recommendations Please
You could do grandsport calipers which are supposedly stronger.
I thought maybe the C5 Z06 brake kits will fit under stock wheels as well.
08-31-2015 | #42 |
I think you need a spacer for the C5s.. unless you have the A molds.
08-31-2015 | #43 | |
08-31-2015 | #44 | |
I doubt that with the use of the majority of the eBay adapter bracket packages that some buy there's any substantial benefit to what they've accomplished. The C4 Grand Sport caliper is determined to be stouter in some critical areas from a design aspect but is it required for the majority of the users? Likely not. If your car is a '91 I believe the "upgrade" to the '92+ pedal ratio could be considered a true "upgrade". If your car is a '92 then you've got the ratio and I believe I'd just relax, buy a pad that's meant for 95% of your driving. If you actually have a need for a performance pad/rotor combination, buy and install when the need arises. Simple as that, different pads/rotors for use on track days or whatever. The "bias spring" is generally accepted as being a desired modification so maybe that deserves some consideration. Those with A-molds can buy the "bling" spend all they want to do the "show me". Those that use the brakes have product that performs and there's no "bling" involved. Last edited by WVZR-1; 08-31-2015 at 10:56 AM. |
08-31-2015 | #45 |
I'm a relatively new ZR-1 owner, and recently noticed that the pads only contact the outermost few inches of the rotor. Like, the pads aren't the same width as the rotor face area. Is that normal?
My '91 has new rotors and stock calipers (as far as I know). I looked at the new rotors recently and saw that much of the rotor face nearest the center isn't scuffed, isn't used. Seemed odd, and made me wonder if I had mismatched parts. I can't think of a reason GM wouldn't use the entire rotor surface. Maybe they were worried about caliper flex? |
08-31-2015 | #46 |
ZR-1 (90' and 91') Wilwood Rotors and C4 to C5-Z06 Conversion
ZR-1 (90' and 91') Wilwood Rotors and C4 to C5-Z06 Front Brake Conversion with A-Molds Specific Brake Parts by Wilwood The KEY Element is the offset of the Rotor to match the offset of the Caliper Bracket. This Wilwood Rotor with Z06 Caliper Modification described herein is IDENTICAL on BOTH the 90' ZR-1 and 91' ZR-1. BLING is Good.....so is LESS BRAKE FADE Also the Bearing Hub does not see near as much heat on a high speed stop when compared to STOCK Single Piece Rotors.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-31-2015 at 12:36 PM. |
08-31-2015 | #47 |
The fronts are 17 inch wheels in c5 Z06 but rears are 18s i believe my brother said. But rears are smaller so they might fit
08-31-2015 | #48 | |
Johnny5 restarted this thread this week and he wants to use his sawblades. So, I don't think he can use these options below, right?
I'm in the same situation. My track tires are mounted on sawblades (but I might change that). Quote:
08-31-2015 | #49 |
The C5Z rear brakes have an drum type E Brake. Won't work on the latter C4 like the ZR-1, without some type of adapter, which uses the rear caliper as the EBrake. As WV stated, not much advantage really.
08-31-2015 | #50 | |
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-31-2015 at 01:52 PM. |
