12-08-2014 | #41 | |
Re: Brighter Aftermarket Headlamps
As for fog lights, right now, my car has stock fog lights. There is a guy in my Club with a base '93 who put an HID fog light conversion in his car. He had some trouble with it at first due to a couple of defective ballasts but, I saw him two nights ago and he said they are now working fine. As for other fog light choices, such as high-wattage incandescent bulbs or LED bulbs, I haven't researched that, yet. Sorry.
12-08-2014 | #42 | |
Here is the reality. The LEDs burn out your toast, The LEDs meet a rock your toast. The HIDs burn out. You replace the bulb, you catch a stone you get a re lens. Not an option with the LEDs. Did your friend get the same kit as mind or a $99 Ebay kit which there is zero comparison? Sorry Hib not worth my gas or time to debate you as your mind is clearly made up. Go boldly.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 12-08-2014 at 12:50 PM. |
12-08-2014 | #43 | |
12-08-2014 | #44 | ||
Let me know if you change your mind.
12-09-2014 | #45 |
Please just Stop it!
12-09-2014 | #46 |
So...Mark is looking for content for the magazine or he's so busy that he's looking for someone else to edit the magazine?
12-09-2014 | #47 | |
To meet Federal Motor Vehicle Safety Standard (FVMSS) 108, GE Lighting had to provide some objective test data to the US DOT as to the expected service life of the Nighthawk LEDs. Also, since the original target market for the product was the heavy-duty, long-haul trucking industry which, generally, is cost conscious; the durability had to be outstanding to offset the high purchase price. Nighthawk LEDs have a 15,000-hr life expectancy. To put that in terms to which we Zroners can better relate, if you had a NIghthawk LED which lasted only half its design life, you'd have to drive your ZR-1 337,500 miles at an average of 45-mph with the headlights on all the time to reach 7500-hrs in service. No HID headlight system in OE or aftermarket use in a passenger car has that long a design life. That might, also, be why there are no heavy trucks sold in the U.S. equipped with HID headlights as original equipment. To achieve that kind of reliability would be cost prohibitive, i.e. they would cost well over the $1000+ you paid for your CorvetteHID.com products. I don't think I'll ever have an LED "burn out" due to over-voltage. Nighthawk LEDs can be run at any voltage between 11 and 33 volts. That wide range is by design because some big trucks have 28-volt electrical systems. A ZR-1 has a 12-volt system and would likely catch fire before it would produce more than 33-volts to the headlights. Light emitting diode technology is exceptionally durable in other respects, too–more durable than both incandescent bulbs with filiments and high-intensity discharge bulbs. As for catching a stone? Granted, if a fairly large rock hit a Nighhawk LED, it might damage the lens, however, it would need to be pretty large stone to do that because, to meet FVMSS 108, a headlight lens, regardless of its material–glass or polycarbonate–must have certain minimum properties as to abrasion- and shatter-resistance. My experience with other products which must withstand modest impacts is that polycarbonates are more impact-resistant than glass. For example, that's why Sprint Cup cars have Lexan rather than glass windshields. I agree, that if a Nighthawk LED gets hit hard enough to break the lens, you're screwed and out 280 bucks but, I also surmise that, for a given, minimum stone size/mass which will break a glass lens, the polycarbonate lens will survive. That is, for that given little rock hit, you're going to exercise the CorvetteHID "relens" option but my Nighthawk may survive. But hey...if you want to come on over to CA for a headlight "shoot out" we can add rock throwing to the list of comparisons. Lastly, I've driven my ZR-1 almost 85,000 miles in nearly 20 years. I've had four different kinds of headlights in the car: stock polycarbonate sealed-beams, Hella glass, Cibie glass and now GE polycarbonate and never have experienced a broken headlight due to impact. That said, there is one type of driving I've not done with my car, but which would be highly susceptible to causing headlight damage and that's high-speed on gravel roads behind other vehicles. If I did that, I guess I'd have to have some of those little metal screens over my lights. Bottom line...I'm really not too worried about Nighhawk LEDs "burning out" or "shattering," however, if I were, you can be damn sure I'd have raised that issue in my CAC product evaluation article.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 12-09-2014 at 12:23 PM. Reason: added link. |
12-09-2014 | #48 | ||||
That would be cool to do but to be honest Im satisfied and have nothing to prove by throwing stones at my own lights. Remember they are pricey Quote:
12-09-2014 | #49 |
12-10-2014 | #50 |
Peter Z!
