06-07-2014 | #41 |
Re: Help! Unable to rev past 5000
What EXACTLY did you ask Marc to do w your chip?
06-07-2014 | #42 | |
Jim |
06-07-2014 | #43 | |
That's the one I mention in an earlier post. White plug 2 wires under plenum. Pete
06-07-2014 | #44 |
06-08-2014 | #45 |
R U sure? The ECM just needs to see a +.7 v signal from the Differential Map Sensor. That's what allows secondaries to open. I don't have that solenoid under the plenum. By changing the calibration, the sensor always puts out the necessary signal.
06-08-2014 | #46 | |
Dom,at this time I don't know how the chip was programed. So I would suggest plug in the solenoid under the plenum and the MAP sensor under the ECM.(don't need vacuum) I mentioned both sensors on an earlier post. I figure this is easy and free instead of throwing parts at it. Also if the error code was programed out of the chip it will not show a code. Pete
06-08-2014 | #47 |
I had him do whatever needs to be done to remove the secondaries. He also did the usual stuff with his chips. 1 to 4 skip removed, radiator fans on sooner, full power default. Maybe I can send the PROM back and have him verify the settings. When I talked with him on Friday he seemed kind of stumped too. You guys are the best. Would have a boat anchor without you all!!
Chris
91 ZR-1 Red on Red #922 |
06-08-2014 | #48 | |
Pete
06-08-2014 | #49 | |
So it worked fine w Marc's cal changes but then it didn't. correct? You get a code if you don't let off because the ECM doesn't set a code unless the malfunction occurs for longer than 2sec. You're sure you are not getting a Code 64 or 44?
Cam sensor error is a Code 17 Quote:
06-08-2014 | #50 | |
The only code I get is a 17 when I stay on it when it starts missing. I have replaced the cam sensor already to rule that problem out. Chris
