#41 |
![]() Join Date: Jun 2015
Knock wood no problems on the Z. I was asking about a previous build that used a good deal of oil but has really good compression.
#42 |
![]() Join Date: Jan 2010
With good compression, I believe typical suspects are valve guides/seals, oil rings, plenum leaks & gasket leaks.
#43 |
Just a update, it's up & running after sleeve/ring replacements. While we were there, the stock exhaust cams were replaced with Stage 1 ones, the upper was ported more aggressively & a x-pipe added. Waiting for spring for Tuning.
#44 |
Al,
I think you'll be pleased with Pete's exhaust cams, especially w the right tune. Should be interesting to see how they work w the Split duration intakes. W Xpipe, you want to look into using Z06 exhaust control valves.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 01-23-2016 at 08:57 PM. |
#45 |
![]() Join Date: May 2011
Tim, Thanks for the update.
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
#46 |
Yes.....I need another set.....please keep your eyes open. I have the same setup on the other 2. Thanks!
#47 |
#48 |
Woo hoo, That will sure be fun to drive.
