06-02-2014 | #41 | |
Re: Why not just remove thermostat?
06-03-2014 | #42 | ||||||
Increasing the surface area of the radiator in the LT5 can be accomplished only by adding additional cores. Adding additional cores increases the resistance to air flow. Compensation for reduced air flow due to the increased restriction of more cores can only occur with greater air flow. Quote:
. Quote:
Damage to radiators has occurred from excessive restriction of the "bypass system" which was part of the LT5 cooling system, designed to prevent radiator damage. Quote:
You need to understand that thermostats DO NOT regulate MAXIMUM temperatures, but only MINIMUM opening temperatures.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 06-03-2014 at 04:43 PM. Reason: Fix puncuation & grammar |
06-03-2014 | #43 | |||
Good stuff there Jerry...
Colder-rated thermostat for cooler running temps is one of the biggest myths I know of. But Hog said his twister DOES turn "so much so" cooler, with only the lower-rated stat. Quote:
And are you surprised that Jim Nolan's cooling system doesn't keep his mill running closer to 185', which his ECM is re-coded for? Quote:
06-03-2014 | #44 | |
Radiator Cooling Fans Operation
I would add........ Turning the cooling fans on earlier has the same effect as opening your thermostat earlier (160 deg). After a steady state coolant temperature is reached where your fans and my fans are both on no matter when I turned my fans on the cooling effect is the same. But then again ....if you are operating where the coolant temperature is 218 deg (just below the secondary fan normal operation) then turning on your fans at say 200 deg would be a definite advantage. Same goes for the coolant temperature at which the primary fans turn on at 228 deg. If you have coolant temperature of 227 deg then turning on your fans at a lower temperature will be an advantage. But if we both have a standard radiator and the coolant temperature is at least 228 deg where both your fans are on with my fans turning on at a lower temperature...there would be no advantage to me turning my fans on at the lower temperature in that situation. Now having said that......There is a caveat My fans come on at 205 deg and off at 200 deg but then again I have a Ron Davis Radiator. Turning my fans on earlier (at a higher temperature than my 180 deg thermostat) will have a greater cooling effect (because of the Ron Davis Radiator). My coolant temperatures are actually less than the standard fan turn on temperature of 228 deg or 219 deg (I recall Secondary fan turns on at 228 deg F and Primary fan turns on at 219 deg F. I also recall fans turn off with a drop of 11 deg F more or less). With a chip....Marc sets the fans on at 205 deg F and off at 200 deg F. Both our fans are on at 205 deg (Programmed in the modified Chip) but my fans are pulling air through a Ron Davis Radiator and can take advantage of the lower coolant temperature operation fan turn on programmed by Marc. In other words....because of my Ron Davis Radiator I would be normally running the ZR-1 with the fans OFF (because I am below the normal coolant temperatures that would normally turn the fans on). So....I turn my fans on sooner (Marc Chip) where the full advantage of the Ron Davis Radiator can be experienced. Dynomite aka Cliff I hope I made my self clear I know.....clear as mud
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-03-2014 at 03:03 PM. |
06-03-2014 | #45 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 06-03-2014 at 02:56 PM. |
06-03-2014 | #46 | |
06-03-2014 | #47 | |
06-03-2014 | #48 |
06-03-2014 | #49 | |
Especially on the passenger side where the oil cooler hoses are located.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-03-2014 at 03:30 PM. |
06-03-2014 | #50 | |
http://zr1specialist.com/HAT%20Web/a...%20Coolant.pdf http://zr1specialist.com/HAT%20Web/a...d%20Gasket.pdf |
