Old 04-23-2014   #41
Default Re: Headers Installation...
Originally Posted by 4-cam View Post
Seems like every time I touch an electrical connector on my Z I break it. Many tools out there to remove the pins on these. This is the one I got. I was able to find all connectors from Rockauto or napa. Check your knock sensor connector while your under there. Mine fell apart when I touched it.
What is that specific tool called or where did you get it?
Thanks
Old 04-23-2014   #42
Blue Flame Restorations
Thanks
Looks like a sputnik
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-23-2014   #43
4-cam
Lisle - Terminal Tool LIS-56500 I got mine on ebay but im sure other sources are availble.
If you get a new connector it has wires already in the connector. This tool will release the wires and allow you to use the existing terminals so you dont have to splice the wires. You Tube has some good demonstration videos on how to use it. Just search terminal tool.
[I]4-cam[/I]
[I]1991 ZR-1 Blk/Gry #31[/I]
[I]SW Headers/Xpipe- Dynomax Muffs[/I]
[I]Ported top end[/I]
[I]Secondaries Removed[/I]
Tune by Dominic
4-cam is offline   Reply With Quote
Old 04-23-2014   #44
Paul W? How much, Paul? $PP? M/O? Check?
PM'ing you my address here...
I think it took :15 to get the pipes down here; took my time, oiled the bolts...
(does seem like I was here a month ago )
Out of stock. But, I can make another batch if you (or anyone else) needs one
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 04-24-2014   #45
Thank you.....just got two on Ebay
Old 04-24-2014   #46
mike100
Originally Posted by efnfast View Post
My install guys fabed up an extention for the O2 sensor. Someone makes one, wish I knew in advance.
The 3-wire O2 sensor was an interim oddball configuration until GM went to the more common 4-wire unit. I made my own extensions. There is a post on this forum somewhere with all the weatherpack connector parts listed that you can get online or at Napa. You only need it for the passenger side.
Old 04-24-2014   #47
4-cam
Nice going.
I think I had every extension I own with every conceivable combination of socket and adapter on the floor when I did mine. Didn’t know I owned that many tools till I had to put them away.
[I]4-cam[/I]
Tune by Dominic
Old 04-24-2014   #48
4-cam
D side was the hardest. P side the easiest I found. Could have been my learning curve.
[I]4-cam[/I]
Tune by Dominic
Old 04-24-2014   #49
Franke
I saw you got it all on and fired up. Did you get emissions done yet? Not sure if Schrade has to deal with that in NC.
Old 04-24-2014   #50
4-cam
Schrade
Just condensation i would think. You do get a bit humid in NC.
Do you have to go thru emissions in NC? I know you were looking at adding the AIR tubes back on.
I did get mine fired up and it failed emissions. I am about Double the HC limit. NOX and CO are really low. The testing station had issues with the dyno so it sat to long. Plugs are really running Hot. Cats are not getting hot enough. Dominic advised running a colder plug and is reviewing the Data Log. We will get it ironed out.
[I]4-cam[/I]
Tune by Dominic
