Old 08-21-2015   #41
Default Re: Pulleys
Originally Posted by efnfast View Post
Soooo Cliff, how do the guys with electric water pumps do in traffic. Electric pumps are not engine speed dependent.
We are right back with Pete as he has used Electric Water Pumps
Old 08-24-2015   #42
Pete
Pete's Avatar
Default Re: Pulleys
I had a 55GPM electric WP in my Z for about 4 years, as everybody knows i don't road race or any kind of circle track racing only drag race.
The 55GPM with 160* t-stat with holes and fans on at 170*it was awesome in hot summer traffic if i left my Z idling for a while she would run up to temp fans on at 170* it would cool her down 165* fans would go off it would do this all day long.
Remember the electric pump constantly pumps 55GPM no matter the RPM.
Went back to stock water pump what i notice is my fans run nonstop (fans on 170* same T-stat) in traffic once i start moving and get air to the radiator is the only time she will cool down to 160-165.
I think with stock water pump we need more air to radiator.
Tony Davila has tested/added an extra fan to the front of his radiator and he has mentioned it helped keep temps down.
Hope this helps.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-24-2015   #43
Default Re: Pulleys
One point regarding engine control and coolant temps. I believe Pete runs his calibration in Open Loop. The ECM goes Closed Loop ~ 64C, but it does not update the BLMs until CTS reaches 80C or 180F. So if your chip is programmed for Closed Loop, it will not update fueling as you drive because it does not "Learn" at temps under 80C.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-24-2015   #44
efnfast
Default Re: Pulleys
So, same air flow, more water flow equals better cooling.
Old 08-25-2015   #45
Karl
Karl's Avatar
Default Re: Pulleys
I have a thought about under drive on the water pump. I know they cavitate at high speed, but at low speed is the pump moving enough water to cool coolergine. Maybe over heating at low speed is not an air flow issue, but a water flow issue. If this goes anywhere, it may warrent a new thread. Sorry Pete, didn't mean to side track the thread.
I have the ud water pump pulley and after the install my engine temps always are near 180 - 190. Hottest day here in Chicago as about 93* with high humidity, 45 minutes in rush hour traffic and my car gets up to 214* at most. Once I start moving again the temps come down quickly to ~200. This is with the a.c. on and a fluidyne radiator.
The car can idle in the hot weather all day and not pass 200*. I believe with rush hour traffic the heat from all the cars, and me needing a new front air dam I can run cooler.
I have installed a pusher fan in front of the radiator but I have not needed to connect it.
I have no regrets with my setup and no over heating issues.
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 08-25-2015   #46
Default Re: Pulleys
My experience w the Fluidyne is the same as Karl. I have the fans come on at
87 and 90C and that's enough to keep temps below 212F even in the 90s. Once driving, temps don't get above 190F.
Old 10-28-2015   #47
Default Re: Pulleys
Originally Posted by Pete View Post
I will be placing orders for pulleys if anybody is interested pleas email me
with your orders Petezr1@gmail.com
I do take PayPal (petezr1@gmail.com) please add $6 for fees and $20 for shipping within the USA.
Please specify color (Black,Blue,Red,Silver) and for the Water Pump underdrive or stock size.
These are half the weight of the stock steel pulleys and look much nicer.
These could take 2-6 weeks.
Thanks
Pete
Pete.....received the Stock size Aluminum Black Water Pump Pulleys today.....very very nice. Can you get one more Stock size Black Water Pump Pulley by any chance?
Thanks,
Cliff
P.S. For those thinking it is complicated to remove the original stock water pump pulley.....NOT
All you have to do is remove the Air Duct and Air Horn (6 torx). Then remove 4 (8mm heads) Water Pump Pulley bolts (Take tension off the belt tensioner and hold). Slip old water pump pulley off and up in front of the Alternator and out. Reverse for installation of New Aluminum Water Pump Pulley.
Old 10-29-2015   #48
Pete
Pete's Avatar
Default Re: Pulleys
Cliff, I don't have one on the shelf but can order one more for you.
The only issue is these are the last ones with the holes he doesnt want to do holes the only way he will do them is at extra cost.$100
The holes started cause i wanted them as light as possible for myself.
Now on no holes same old price with holes add $100
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 12-09-2015   #49
Default Re: Pulleys
Pete
Carter added six holes in the Billet Aluminum Water Pump Pulleys. Unbelievable Perfect Modification. Thanks Pete for the suggestion on having Carter do a modification adding holes and thanks Carter for a Perfect Modification
Old 12-09-2015   #50
Pete
Pete's Avatar
Default Re: Pulleys
Looking good.
Always thinking outside the box.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
