#41 | |
Do lights dim when you turn key to start? I always install the Starter Relay and along with that always recondition the starter solenoid and points (and check armature bearings for smoothness and starter Brushes).
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
#42 |
![]() Join Date: Oct 2006
Lights do not dim. Solenoid does not click. It acts just like a VATS problem but it has been bypassed.
#43 | |
I assume you installed the Starter Relay taking direct current from battery to Starter Solenoid when activated by a lower required current to activate the Relay itself through the Clutch Switch.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-01-2015 at 08:39 PM. |
#44 |
No have not touched clutch switch or added relay. It is bone stock. I am to old to be removing battery boxes and adding another relay. Could it be the clutch switch or original relay?
#45 |
It could be....since when engine warm may take a bit more current to move the Solenoid and as such may be beyond the capability of the clutch switch to handle that current. In other words you have less voltage at the Starter Solenoid because of the greater resistance in the Clutch Switch Circuit at a time when the Solenoid takes a bit more voltage to function when engine warm.
#46 |
Think for a start it would do any good to bypass the switch?
#47 |
It is worth a try and would help diagnose the situation.......that would eliminate (at least for now) the switch as the culprit if in fact it still does not start. If it starts that would point to the switch as the item having excessive resistance in the start circuit providing voltage/current to the starter Solenoid (which may be a bit of a culprit being sticky and requiring more voltage (greater magnetic field) to activate).
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-01-2015 at 09:17 PM. |
#48 |
Thanks will give it a try.
