08-21-2013 | #41 |
Re: About to start header install just wanted some input and had a few questions...
Yes that's my thread on CF So I'm guessing its normal that I have an early build 94 with a black tag? I was happy to see it was a black tag when I first got under the car but then got wondering if perhaps it was swapped or something.
08-22-2013 | #42 |
Got the pass off ... Forgot the egr tube.. How does the clamp come off the manifold?
08-22-2013 | #43 | |
I have no clue what clamp you are looking at.....must be something on 94 that is not on 91' For a minute when you said "pass" I thought you said something else |
08-22-2013 | #44 |
Pic inc
08-22-2013 | #45 |
08-22-2013 | #46 |
jam a screwdriver in there and wedge it apart. There's actually a tool to re-clamp those.. similar to what they sell to re-clamp CV boots.
08-22-2013 | #47 |
Well I'm a little stumped been busy all day getting the wheels and tires assembled and mounted. And the pass manifold is off just stuck by the egr tube. Have to figure out how to get that off tomorrow.
Is there an egr valve? I'd like to remove the egr tubing And piping but don't want any codes popping up. If it won't pop a code ill get a gasket made for the plenum and bolt it up and ill get the header welded shut. |
08-22-2013 | #48 |
You also can remove those brackets that look like the hold the motor mount...they don't...you'll see.
08-22-2013 | #49 |
I had an EGR port in my SW Headers for the 91' because I forgot to tell SW to eliminate it. I just took a bolt about that size and ground the tip a bit so it was slightly tapered and pounded it in to the SW EGR port as a press fit...works perfectly.
08-23-2013 | #50 |
My sw headers where delivered with the egr tube too, I closed that hole with an m10 stainless bolt, using a good tap for it, to make thread inside.
