Old 08-12-2013   #41
Default Re: 402 Build Project Udate
Going to have to agree with Pete....mine had a small leak from the freeze plug....and the machine shop did not disturb it when they cleaned and polished...I had my Callaway on the lift, so I had Pete pull the trans....
We also had alot of fun with a steel pilot bearing
Old 08-12-2013   #42
Jagdpanzer
Jagdpanzer's Avatar
On thier LT5 billet cranks Bryant welds the freeze plugs in after installation so if the rear plug is leaking I may have a real headache on my hands.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-12-2013   #43
Polo-1
Are you sure they welded the FW side plug? I had mine all welded but that one. This was for both the 402 (moldex) and the 380 (stock re-ground).
Good to see it running Phil
Old 08-12-2013   #44
Marc Haibeck
Hi Phil,
If the end plug is welded it must be welded 360 degrees. If it is tack welded it will distort between the welds and leak.
You might be able to seal it by driving the existing plug further into the crank and installing a second plug behind it. There should be about .5 inch of bore available behind the plug before it intersects with diagonal galley from the crank arm.
Since the bore for the plug will be rough from the weld I suggest sealing the new plug with epoxy.
You can test for a leak by installing the exhaust system without the transmission. That way you can visually inspect the repair with the engine running.
Best of luck.
Old 08-13-2013   #45
Jagdpanzer
Jagdpanzer's Avatar
Pulled the tranmission and bellhousing off this evening and found the source of both issues. The metal rubbing sound was from the valley drain tube coming in contact with the new McLeod aluminum flywheel I'm using now.
The McLeod flwheel is about 8 lbs. heavier and thicker on outer radius of the front side than the Fidanza I was running before. A a little contouring with a ballpeen hammer will take care of this issue.
The source of the oil leak is from a hole in the the welded in rear crankshaft freeze plug.
As you can see the plug is welded in a full 360 degrees. The pin hole leak is at the 5 o'clock position.
Marc, I will follow your suggestion of epoxying in a new plug behind the old one give it a running test before putting everything back together.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-13-2013   #46
Phil,
Ask Lgaff about the McLeod. He was running one on the 90 I believe. What was the point of switching out the Fidanza?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-13-2013   #47
Jagdpanzer
Jagdpanzer's Avatar
Dom,
I wanted to try out a heavier flywheel this time and the price was right.
Lee,
Would you mind sharing your McLeod experience?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-13-2013   #48
rkreigh
maybe a little JB weld. be better if you could spot weld it to seal it up.
glad you found the problem so quickly and the beast is again ALIVE!
but who the hell am I telling, Phil has forgotten more about LT5s and mechanical stuff than I'll ever know
thanks for posting up all the pics, car is beautiful hope to see it at carlisle, but if not let me know if you need a spare vette
you can drive the ZR-1 or the turbo Z06 up!
cya
95 390 LPE ZR1 (505 rwhp)
Old 08-13-2013   #49
I was having an issue with the clutch not disengaging, it might have been a perfect storm of issues:
1)The rear crank plug was leaking on the flywheel
2)The Mcleods offset was different than the Fidanza causing it to "closer" to the clutch
3)I was running a weighted Centerforce pressure plate, which has caused issues with disengaging for a few other folks I knew
In the end I cannot say which one specifically caused the issue, but all is well at this point
Old 08-13-2013   #50
Lee,
Thanks. I thought I remembered there was a difference between the Fidanza and McLeod.
Phil,
What was the result you were looking for using a heavier FW?
