Old 04-27-2014   #41
efnfast
Default Re: What MODS Have You Done To Your ZR-1??
Tony, so that's what my car looked like before I did a few mods?
Old 04-27-2014   #42
Tony Davila
Tony Davila's Avatar
Yes sir indeed. Don't you just love sarcasm?
The easier question is to ask what have you not done yet to your car. I have owned it since 1998.
Need:
stroker, rollbar, maybe Nitrous.......then I think I'm done. Maybe
Tony Davila is offline   Reply With Quote
Old 04-27-2014   #43
LantanaTX
I bought my car a couple of weeks ago and still trying to figure out what mods it has. Carfax says it was two owner car. first owner traded it to a dealer and second owner bought from dealer so history is lost. The obvious mods are the gray paint, color keyed door handles and wheels.
I did find something interesting folded up in the FSM that came with the car. It was a printout of an email from Doug Rippie Motorsports in 2004 to a Jan Timmerman that referenced a huge list of engine parts including pistons etc. I sent an email to Jan Timmerman to see if this was the original owner and what was done to the engine. If buying a ton of parts from Rippie, maybe my engine is not stock?
[SIGPIC][/SIGPIC]1991 #0663
LantanaTX is offline   Reply With Quote
Old 04-27-2014   #44
Tony Davila
Lets hope Rippie blessed your engine.
Old 04-27-2014   #45
Mitsumark
Tony-..I know that hood scoop is an overlay on the stock hood..Who makes it?Greenwood?
Mitsumark is offline   Reply With Quote
Old 04-27-2014   #46
Schrade
Mine was 'bone stock', except for the 91 - 95 body conversion (think it was done since the car had taken a hit in back, although I just found a piece of glass inside the hood mount, IN THE FRONT!
The ZF was first to go, now the 2' port hardware, now it looks like the AIR plumbing will be removed, traded the Aluminum pinwheels for Black A-Mold [repro's] on the corners, now the exhaust is migrating from the sigline to actually ON the car. And the painted top end, the GS stripe to take the edge off the Red - DON'T like Red...
Old 04-27-2014   #47
Stock.........all stock.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 04-27-2014   #48
Tony Davila
Yes sir, it is a Greenwood. Bought it through Ecklers.
Old 04-27-2014   #49
Blue Flame Restorations
Frank, you silly purist!!!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-28-2014   #50
Hib Halverson
Automasters "Street Skinner" engine package consisting of:
--Greg Van Deventer ported/polished heads, housings and plenum
--larger main throttle bores
--reset cam timing, engine blueprinting by Scott Skinner
--working secondary port throttles
Ported stock exhaust manifolds w. stock cats
RC Engineering injectors
MSD Coils
MSD Super Conductor plug wires.
Denso IT-22 spark plugs
Throttle body heat bypassed
DRM open element air filter housing with Green Filter
Home-built air duct brace
Custom built exhaust system consisting of:
--Flowmaster two-into-one collector
--Flowmaster resonator
--96 Grand Sport mid-section wrapped with DEI Titanium exh. wrap.
--Flowmaster 50-Series Delta-Flow mufflers, 3-in in-and-out
--Stock exhaust tips
170° thermostat
Fluidyne radiator w. straight water and Red Line Water Wetter coolant
Goodyear Gatorback drive belt
Fluidyne 9-row engine oil cooler
XRP Braided stainless steel covered oil cooler hoses with AN-12 fittings
Marc Haibeck calibration w. reduced secondary delay and 14-mph EGR on
Mobil 1 oil filter
Red Line 10W30 engine oil
Red LIne Power Steering Fluid
McLeod aluminum flywheel
MdLeod clutch
McLeod clutch disc
ZR51 Performance C-Beam plates
Hurst/Rinehart shifter
Stock ZF S6-40 w Red Line Light Shockproof lubricant
Stock 3.45 axle w Red Line Heavy Shockproof lubricant
Drain plug in axle housing
Braided stainless steel covered Teflon power steering pressure hose
Overhauled and revalved Delco-Bilstein SRC shock absorbers
96-Grand Sport brake calipers
Slotted brake rotors
Braided stainless steel covered Teflon brake hoses
Goodyear F1 Supercar tires, stock sizes, on original wheels
GE Nighthawk LED head lamps
factory export tail lamps
Quartz Halogen reverse lights
External cellular and UHF-FM antennas
New Delco-Bose speaker assemblies
Pioneer/Zip Products DEHK-3500U AM/FM/CD receiver w iPod support
WeatherTech Cargo area mat
Zip Products ZR-1 floor mats
Cadillac CTS-V metal lug nut covers
Intake plenum signed by Dave McClellan at the "Last ZR-1" commemorative
event 1995
When engine was finished in 1998, dyno'ed at K&N Engineering
413 rwhp@6500 RPM SAE corrected
