Old 02-27-2013   #41
Blue Flame Restorations
Default Re: Bought Out A/O Engineering's Leftover Stock
The inverted box looks like a no brainer. With some fresh air ductwork, it would be a cool piece. If this was combined with the BIG MOUTH option, you'd have all the air you'd need, most likely.
A lower air dam with the cooling ducts could also be used instead of routing the ductwork to the brakes. Route to the air cleaner.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 02-27-2013   #42
Originally Posted by VetteVet View Post
Brett,
I replied to your PM, but here is the gist for everyone else:
What I have is a housing that is inverted. It mounts to the radiator shroud and attaches to the air duct in the same manner as stock. The kit included an air filter lid which had a scoop incorporated into it, a template to cut the stock radiator shroud and a seal to seal the housing to the shroud. The air filter and lid/scoop hangs down into the air stream feeding the radiator and forces the air into the housing. It sounds like exactly what Robert was inquiring about in post #4 of this thread.
Here are some pics:
Hope this helps.
When I spoke to Dan at API, he was very helpful, but stated that the unit is no longer in production. He is digging up whatever pieces that he still has left and will contact me soon. He is also willing to provide me with the installation instructions and template for cutting the radiator shroud.
Pics of an L-98 version of this system can be found at http://forums.corvetteforum.com/c4-p...ntake-cai.html
Jep
Jep, does this unit use an air filter?
Old 02-27-2013   #43
Yes Stock one ( well stock replacement )
Old 02-27-2013   #44
Thanks, Jeff
Old 02-28-2013   #45
VetteVet
VetteVet's Avatar
Sorry, Brett. I missed that question. Jeff's got it covered, though.
I haven't heard back from Dan @ API yet. I'll give it a few more days and then give him another call.
Jep
Old 03-01-2013   #46
I have an intriguing idea for forcing COOL air to the air cleaner assembly. I will try it on my 91 before BG. If I can bring it installed, it may generate some good dialogue.
Old 03-02-2013   #47
xlr8nflorida
xlr8nflorida's Avatar
I had this kit probably 10 years ago. I wound up selling it because I realized I was going have to cut the bumper support which I didn't want to do. Also, I don't think there is much to be gained HP wise as many studies have shown it on the forum. It definitely looks cool though.
I wound up selling just the front license plate section for like $150. Another guy picked up the guts.
Old 03-09-2013   #48
Received all of the A/O remaining stock today. Wasn't much but it's all new.
Airbox Covers
Hoses/Clamps
Diffsuers for the air inlet (I have a mold for these now as well)
The front inlet housings will be vacuum formed. I tried to make a fiberglass mold but there just isn't enough draft on the part for it to give acceptable parts.
It will be a few months before the vacuum formed tooling is completed. Probably mid Summer.
FYI, if anyone is interested?
Old 03-09-2013   #49
Fully Vetted
Fully Vetted's Avatar
Most definitely interested...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 11-24-2015   #50
9T1 Red ZR1
9T1 Red ZR1's Avatar
Hello,
Any new developments with this?
Thanks,
Bill
LT5 Red/Red
9T1 Red ZR1 is offline   Reply With Quote
