Old 02-18-2013   #41
Default Re: Ooooo! She luvs cold air!!
Originally Posted by Fully Vetted View Post
I'm actually probably closer to 510-515 right now depending on what percentage you use for driveline loss (let's no get started on that again). Either way, you think I could pick up 20-25 chp?
Didn't the 405 cars use a different profile for the cams? Wondering if that would affect the gains you would experience w Pete's cams. We know that Dave J. ( a 94 AB) is in the 430-440 rwhp range, depending on exhaust, w Pete's intake only cams and full porting. BTW, I am
using 15% parasitic loss.
Old 02-18-2013   #42
Originally Posted by LancePearson View Post
Paul, you are exactly right...got my references mixed up.
If I had been slowly building my experience base at triple digits on a country 2.3 mile long isolated, no driveways flat and straight road it would be fun to report that 125 to 140 mph is getting much more comfortable and familiar. But then, we all know that's going 85 mph over the state speed limit so that must just be a rich expression of a fantasylife, right?
I'm sure a lot of us will get to interact in Bowling Green from all over and I want to see and hear some of these tuned cars with the power at your disposals. I haven't seen the itinerary yet but I hope there is a part day cruise as part of it when there. Hope so, or a check drive.
The June 1/2 mile in Chicago area I looked at the fliers for and it looks very interesting, there and in another location I think. You are doing it, Paul?
Have someone video it for you if possible. You will be very competitive.
With the 4:10 rear end will it keep you below 150 mph in the 1/2? Any references to compare it to for your own expectations?
I can say that on the hypothetical 2.3 mile stretch mentioned above that it does not seem to take 1/2 mile or much over to get to the speeds I'm fantasizing about and I reference 3:45's and more or less stock lt5 that's just been chipped with Samco hoses and K and N air filter only so you should do way, way better.
I trapped at 121+ mph last fall in the quarter mile on 3.45s. I'm guessing I'll be in 5th gear in the half mile run. So, it is going to be interesting. Hopefully the air will still be cool on the 2nd of June. (Fingers crossed!)
P.
Old 02-18-2013   #43
Blue Flame Restorations
Yeah, I'm the weeny of the group when it comes to high speed (100hp +). Let's say when I was younger, I played with the triple digits at will. These days, I just like the awesome FBI power and sound with all the low end torque at short bursts and rowing through the gears.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 02-18-2013   #44
Fully Vetted
Fully Vetted's Avatar
Yeah, I'm not sure about the cam profile difference. Based on 15% loss I'm at 496 chp and I'm pretty sure I'm making more than that. An engine dyno is the only one way to know definitively what the chp is. Otherwise, it's just a guessing game. It doesn't really matter, anyway. The only thing that matters is what it makes at the ground.
My short term goal, like Paul, is 440 whp. Long term, I'd love to see 450 whp. I'm just not sure we can get much more out of a 5.7L. That's monster power out of 350 cubes. I guess we could swap out the pistons, raise the compression to 11.5 or 12.0 to 1 and run high octane fuel. I wonder what that would net? Someone much smarter than I probably already knows.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 02-18-2013   #45
Fully Vetted
I'm with you. At this point in life I still enjoy a high speed run but it's like I don't need as much as I used to to feel satisfied. The acceleration, though. That is a different story. I just can't get enough of that. That, for me, defines Permagrin.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 02-18-2013   #46
FV,
We know that a stock block 350 can put out 474+rwhp or
~ 560chp. That's Pete's car.
At consistent 129mph trap speeds, I'd say its a pretty realistic number.
Old 02-18-2013   #47
LancePearson
LancePearson's Avatar
FV,
That's ported, relieved, larger tb, no secondaries, sleeved, higher compression but naturally aspirated. There is one fellow, Wayne Hale who you may know, who has one of his three Tennesse Z's with two custom turbos on it which is Way, Way higher than those numbers. If natural aspiration, one thing, forced induction another and higher. Question is: how much is enough? I'd argue for 550-600 chp is more than enough. Got to kepe wheels in contact with the road making progress too.
LancePearson is offline   Reply With Quote
Old 02-18-2013   #48
Fully Vetted
I'm talking about NA stock block numbers. I actually wasn't sure what all Pete has done to his so I couldn't reference his car. That is quite impressive.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 02-18-2013   #49
FV,
Just to clarify, Pete never "sleeved" his motor. I'm not sure what that is unless someone is describing install of new cylinder barrels. Bottom end had 70K on it. I'll let Pete describe the rest if he'd like. But it is pretty impressive for a motor technically under 350CI. As we have been saying in this thread, these motors LOVE to BREATHE!
Once you get beyond 5.7L, there's still N/A motors but w 427 or 441 CI with that kind of hp+ AT THE WHEELS.
